Up to 20% off select tools
Watch Battery Replacement
Views: 4K
View statistics:
Past 24 Hours:
6
Past 7 Days:
44
Past 30 Days:
248
All Time:
3,969
Comments: 0
Go to guide comments
Completed: 5
5 people have marked this guide "completed." Will you be next?
Favorites: 7
7 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 minutes
Difficulty: Easy
Needs More Images
A few more images would make this guide's procedures crystal clear.
Introduction
Go to step 1 ↓
For this project, we are going to talk about how to replace a battery in a traditional watch. These instructions will only work for a traditional screw-off-back watch. To complete this task, you do not need any prior experience, but you will need to have a basic understanding of tools. By doing this yourself, you will save money and gain basic knowledge about watch repair. Make sure you are in a well-lit area with plenty of space.
    1. Watch  Battery Replacement, Battery: step 1, image 1 of 2 Watch  Battery Replacement, Battery: step 1, image 2 of 2
      • Place your watch in the watch holder, and adjust the sizing screw to the appropriate size for your watch.
      • If you do not have a holder, you can hold the watch yourself and still be able to complete the repair.
      Ask FixBot
    2. Watch  Battery Replacement: step 2, image 1 of 1
      • Next, you will have to adjust the dimensions of the watch back remover tool you will use to take the watch back off. The dimensions should be set so the tool properly fits the three connection points on the back of the watch. You can do this by screwing or unscrewing the adjustment screws on the tool.
      Ask FixBot
    3. Watch  Battery Replacement: step 3, image 1 of 1
      • Turn the tool counterclockwise until the back of the watch is completely off.
      • You will need to hold the watch band up while you complete this step.
      Ask FixBot
    4. Watch  Battery Replacement: step 4, image 1 of 2 Watch  Battery Replacement: step 4, image 2 of 2
      Tool used on this step:
      Buy
      • Use tweezers to carefully remove the current watch battery. Next, place the new battery in the same spot and orientation you removed the previous battery from.
      • Do not touch or remove any other piece inside of the watch.
      Ask FixBot
    5. Watch  Battery Replacement: step 5, image 1 of 1
      • Place the back of the watch back on and align the watch back remover tool to the three connection points. Then, turn the tool clockwise until the back of the watch is tightly secured.
      Ask FixBot
    6. Watch  Battery Replacement: step 6, image 1 of 1
      • Check the watch for proper operation and set it to the correct time.
      Ask FixBot
5 other people completed this guide.
Author
with
Maria Pina
217 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 44
Past 30 Days: 248
All Time: 3,969
