Waring Pro SB30 Indicator Lights Replacement
    1. Waring Pro SB30 Indicator Lights Replacement, Back Panel: step 1, image 1 of 1
      • Remove the screws on the back panel with the #1 Phillips screwdriver bit.
      • The screws in the rubber legs of the burner do not need to be removed.
      • If the back panel has never been opened before, the screws may be more difficult to unscrew.
      Ask FixBot
    2. Waring Pro SB30 Indicator Lights Replacement: step 2, image 1 of 2 Waring Pro SB30 Indicator Lights Replacement: step 2, image 2 of 2
      • Using a wrench, remove the bolt from the center of the back panel.
      Ask FixBot
    3. Waring Pro SB30 Indicator Lights Replacement: step 3, image 1 of 1
      • The back panel can now be easily lifted off.
      Ask FixBot
    1. Waring Pro SB30 Indicator Lights Replacement, Indicator Lights: step 4, image 1 of 1
      • Using two thin screwdrivers (or similar objects) wedge them into the slots of the plastic shell of the desired light.
      Ask FixBot
    2. Waring Pro SB30 Indicator Lights Replacement: step 5, image 1 of 2 Waring Pro SB30 Indicator Lights Replacement: step 5, image 2 of 2
      • Push the screwdrivers inward and guide the bulb outwards.
      • Gently grab by the wires and remove bulb from plastic shell.
      Ask FixBot
Sun Fai Lau
588 Reputation
5 Guides authored
USF Tampa, Team 10-7, Brown Fall 2014 Member of USF Tampa, Team 10-7, Brown Fall 2014
USFT-BROWN-F14S10G7
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 18
All Time: 642
