Waring Pro SB30 Hot Plate Replacement
    1. Waring Pro SB30 Hot Plate Replacement, Back Panel: step 1, image 1 of 1
      • Remove the screws on the back panel with the #1 Phillips screwdriver bit.
      • The screws in the rubber legs of the burner do not need to be removed.
      • If the back panel has never been opened before, the screws may be more difficult to unscrew.
      Ask FixBot
    2. Waring Pro SB30 Hot Plate Replacement: step 2, image 1 of 2 Waring Pro SB30 Hot Plate Replacement: step 2, image 2 of 2
      • Using a wrench, remove the bolt from the center of the back panel.
      Ask FixBot
    3. Waring Pro SB30 Hot Plate Replacement: step 3, image 1 of 1
      • The back panel can now be easily lifted off.
      Ask FixBot
    1. Waring Pro SB30 Hot Plate Replacement, Hot Plate: step 4, image 1 of 2 Waring Pro SB30 Hot Plate Replacement, Hot Plate: step 4, image 2 of 2
      • Remove screws #1 Phillips screwdriver bit.
      • The interior edges of the metal frame are sharp and can cause minor cuts.
      • 3 screws on the perimeter of the circle
      • 1 screw in the circle
      • 2 screws on the eletrical stands with wires
      Ask FixBot
    2. Waring Pro SB30 Hot Plate Replacement: step 5, image 1 of 2 Waring Pro SB30 Hot Plate Replacement: step 5, image 2 of 2
      • Remove rod from the center of the plate with a wrench.
      Ask FixBot
    3. Waring Pro SB30 Hot Plate Replacement: step 6, image 1 of 2 Waring Pro SB30 Hot Plate Replacement: step 6, image 2 of 2
      • Remove plate carefully as to not damage internal components i.e. insulator, metal frame, wires, etc.
      Ask FixBot
2 other people completed this guide.
Sun Fai Lau
588 Reputation
5 Guides authored
USF Tampa, Team 10-7, Brown Fall 2014 Member of USF Tampa, Team 10-7, Brown Fall 2014
USFT-BROWN-F14S10G7
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 8
Past 30 Days: 33
All Time: 2,669
