Up to 20% off select tools
Waring Pro SB30 Back Panel Replacement
View statistics:
Past 24 Hours:
4
Past 7 Days:
17
Past 30 Days:
97
All Time:
871
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
The back panel located on the underside of the burner and is held in place by multiple screws. Take care when removing the screws as it may require a good amount of force if the panel has never been removed.
    1. Waring Pro SB30 Back Panel Replacement, Back Panel: step 1, image 1 of 1
      • Remove the screws on the back panel with the #1 Phillips screwdriver bit.
      • The screws in the rubber legs of the burner do not need to be removed.
      • If the back panel has never been opened before, the screws may be more difficult to unscrew.
      Ask FixBot
    2. Waring Pro SB30 Back Panel Replacement: step 2, image 1 of 2 Waring Pro SB30 Back Panel Replacement: step 2, image 2 of 2
      • Using a wrench, remove the bolt from the center of the back panel.
      Ask FixBot
    3. Waring Pro SB30 Back Panel Replacement: step 3, image 1 of 1
      • The back panel can now be easily lifted off.
      Ask FixBot
Author
with
Sun Fai Lau
588 Reputation
5 Guides authored
USF Tampa, Team 10-7, Brown Fall 2014 Member of USF Tampa, Team 10-7, Brown Fall 2014
USFT-BROWN-F14S10G7
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 17
Past 30 Days: 97
All Time: 871
