Waring 51BL29 Power Cord Replacement
  1. Waring 51BL29 Power Cord Replacement, Bottom Panel: step 1, image 1 of 2 Waring 51BL29 Power Cord Replacement, Bottom Panel: step 1, image 2 of 2
    • Turn the blender on its side so the bottom panel is facing you.
    • Unscrew the 22mm Phillips #1 screw on the indent of the panel.
    • Unscrew the 3 screws in the rubber holes.
    Ask FixBot
  2. Waring 51BL29 Power Cord Replacement: step 2, image 1 of 1
    • Remove the bottom panel.
    Ask FixBot
  3. Waring 51BL29 Power Cord Replacement, Drive Coupling: step 3, image 1 of 1
    • Place the screwdriver in the head of the middle flat-head screw.
    Ask FixBot
  4. Waring 51BL29 Power Cord Replacement: step 4, image 1 of 1
    • Unscrew this screw while holding the coupling with your other hand and not allowing it to rotate.
    • This screw may be reverse-threaded.
    Ask FixBot
  5. Waring 51BL29 Power Cord Replacement: step 5, image 1 of 1
    • Once the coupling mechanism has been loosened all the way, gently pull it off the top of the blender.
    Ask FixBot
  6. Waring 51BL29 Power Cord Replacement, Motor: step 6, image 1 of 2 Waring 51BL29 Power Cord Replacement, Motor: step 6, image 2 of 2
    • Unscrew the four nuts in the bottom of the motor cavity.
    • Wiggle the motor until it is free and you can remove it.
    Ask FixBot
  7. Waring 51BL29 Power Cord Replacement: step 7, image 1 of 1
    • Once motor is pulled out, unscrew the 8 mm screw for the green wire from the base of the blender.
    Ask FixBot
  8. Waring 51BL29 Power Cord Replacement: step 8, image 1 of 3 Waring 51BL29 Power Cord Replacement: step 8, image 2 of 3 Waring 51BL29 Power Cord Replacement: step 8, image 3 of 3
    • Unscrew each white wire cap in order to free the motor from the power cord.
    • Once wire caps are removed, separate wires carefully.
    Ask FixBot
  9. Waring 51BL29 Power Cord Replacement, Power Cord: step 9, image 1 of 1
    • Remove the black power cord.
    Ask FixBot
Quinn Vu
116 Reputation
1 Guide authored
Cal Poly, Team S15-G4, Banghart Spring 2017 Member of Cal Poly, Team S15-G4, Banghart Spring 2017
CPSU-BANGHART-S17S15G4
4 Members
5 Guides authored
1 Guide Comment
Where do I get the parts?
Mew - Reply Share
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 21
All Time: 2,411
