Waring 51BL29 Motor Replacement
    1. Waring 51BL29 Motor Replacement, Bottom Panel: step 1, image 1 of 2 Waring 51BL29 Motor Replacement, Bottom Panel: step 1, image 2 of 2
      • Turn the blender on its side so the bottom panel is facing you.
      • Unscrew the 22mm Phillips #1 screw on the indent of the panel.
      • Unscrew the 3 screws in the rubber holes.
      Ask FixBot
    2. Waring 51BL29 Motor Replacement: step 2, image 1 of 1
      • Remove the bottom panel.
      Ask FixBot
    1. Waring 51BL29 Motor Replacement, Drive Coupling: step 3, image 1 of 1
      • Place the screwdriver in the head of the middle flat-head screw.
      Ask FixBot
    2. Waring 51BL29 Motor Replacement: step 4, image 1 of 1
      • Unscrew this screw while holding the coupling with your other hand and not allowing it to rotate.
      • This screw may be reverse-threaded.
      Ask FixBot
    3. Waring 51BL29 Motor Replacement: step 5, image 1 of 1
      • Once the coupling mechanism has been loosened all the way, gently pull it off the top of the blender.
      Ask FixBot
    1. Waring 51BL29 Motor Replacement, Motor: step 6, image 1 of 2 Waring 51BL29 Motor Replacement, Motor: step 6, image 2 of 2
      • Unscrew the four nuts in the bottom of the motor cavity.
      • Wiggle the motor until it is free and you can remove it.
      Ask FixBot
    2. Waring 51BL29 Motor Replacement: step 7, image 1 of 1
      • Once motor is pulled out, unscrew the 8 mm screw for the green wire from the base of the blender.
      Ask FixBot
    3. Waring 51BL29 Motor Replacement: step 8, image 1 of 3 Waring 51BL29 Motor Replacement: step 8, image 2 of 3 Waring 51BL29 Motor Replacement: step 8, image 3 of 3
      • Unscrew each white wire cap in order to free the motor from the power cord.
      • Once wire caps are removed, separate wires carefully.
      Ask FixBot
Dean Becker
485 Reputation
4 Guides authored
Cal Poly, Team S15-G4, Banghart Spring 2017 Member of Cal Poly, Team S15-G4, Banghart Spring 2017
CPSU-BANGHART-S17S15G4
4 Members
60 Guides authored
1 Guide Comment
Hi
Where do I source a replacement motor? I have been looking without success for UK supplier. Thanks Jill
I have a much loved Vintage Waring blender …
Jill Lancaster - Reply Share
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 31
All Time: 3,442
