Up to 20% off select tools
Waring 51BL29 Drive Coupling Replacement
Views: 9.6K
View statistics:
Past 24 Hours:
4
Past 7 Days:
22
Past 30 Days:
114
All Time:
9,565
Comments: 2
1 comment on steps, 1 guide comment.
Go to guide comments
Completed: 5
5 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
The drive coupling is the small gear-like piece attached to the top of the blender base where it serves to attach the motor to the blades. If the teeth are worn down it should be replaced by following these steps.
    1. Waring 51BL29 Drive Coupling Replacement, Bottom Panel: step 1, image 1 of 2 Waring 51BL29 Drive Coupling Replacement, Bottom Panel: step 1, image 2 of 2
      • Turn the blender on its side so the bottom panel is facing you.
      • Unscrew the 22mm Phillips #1 screw on the indent of the panel.
      • Unscrew the 3 screws in the rubber holes.
      Ask FixBot
    2. Waring 51BL29 Drive Coupling Replacement: step 2, image 1 of 1
      • Remove the bottom panel.
      Ask FixBot
    1. Waring 51BL29 Drive Coupling Replacement, Drive Coupling: step 3, image 1 of 1
      • Place the screwdriver in the head of the middle flat-head screw.
      Ask FixBot
    2. Waring 51BL29 Drive Coupling Replacement: step 4, image 1 of 1
      • Unscrew this screw while holding the coupling with your other hand and not allowing it to rotate.
      • This screw may be reverse-threaded.
      Ask FixBot
    3. Waring 51BL29 Drive Coupling Replacement: step 5, image 1 of 1
      • Once the coupling mechanism has been loosened all the way, gently pull it off the top of the blender.
      Ask FixBot
5 other people completed this guide.
Author
with
Dean Becker
497 Reputation
4 Guides authored
Cal Poly, Team S15-G4, Banghart Spring 2017 Member of Cal Poly, Team S15-G4, Banghart Spring 2017
CPSU-BANGHART-S17S15G4
4 Members
60 Guides authored
1 Guide Comment
Do you happen to know where I can purchase this replacement part?
Jessica Dye - Reply Share
Past 24 Hours: 4
Past 7 Days: 22
Past 30 Days: 114
All Time: 9,565
