Up to 20% off select tools
Wall Outlet Cover Replacement
Views: 4.4K
View statistics:
Past 24 Hours:
11
Past 7 Days:
69
Past 30 Days:
275
All Time:
4,361
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 30 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
This guide will help cover a left undone outlet hole or if you are putting a new outlet cover. This guide will help prevent a hazardous zone for children, especially for children under three years old, who can easily put the cord in their mouth or get their hand stuck inside the wall. The guide will also prevent any bugs or mice to get in and out of the hole and it would be best if the hole would be covered up with a proper blank wall outlet cover and this guide is here to help you do that.
    1. Wall Outlet Cover Replacement, Wall Outlet Cover: step 1, image 1 of 3 Wall Outlet Cover Replacement, Wall Outlet Cover: step 1, image 2 of 3 Wall Outlet Cover Replacement, Wall Outlet Cover: step 1, image 3 of 3
      • Remove any hazardous pieces from previous cover.
      • Be sure to remove the two flathead screws to remove any debris, rather than trying to pull off the sharp pieces.
      Ask FixBot
    2. Wall Outlet Cover Replacement: step 2, image 1 of 3 Wall Outlet Cover Replacement: step 2, image 2 of 3 Wall Outlet Cover Replacement: step 2, image 3 of 3
      • Insert any cable or cables that may be hanging out inside of the wall hole.
      • Making a loop in the cable might be helpful to push it inside the wall.
      Ask FixBot
    3. Wall Outlet Cover Replacement: step 3, image 1 of 1
      • Insert two screws into the holes of the new wall cover.
      Ask FixBot
    4. Wall Outlet Cover Replacement: step 4, image 1 of 3 Wall Outlet Cover Replacement: step 4, image 2 of 3 Wall Outlet Cover Replacement: step 4, image 3 of 3
      • Line up the screws in the plate with the screw holes in the wall.
      • Tighten the screws slightly with your hands to ensure that both screws have found the proper holes.
      • Once the screws have been tightened enough to stay in the holes, they should hold the outlet cover in place.
      Ask FixBot
    5. Wall Outlet Cover Replacement: step 5, image 1 of 3 Wall Outlet Cover Replacement: step 5, image 2 of 3 Wall Outlet Cover Replacement: step 5, image 3 of 3
      • Tighten the two screws with a flathead screwdriver.
      Ask FixBot
    6. Wall Outlet Cover Replacement: step 6, image 1 of 3 Wall Outlet Cover Replacement: step 6, image 2 of 3 Wall Outlet Cover Replacement: step 6, image 3 of 3
      • Double check that the wall cover plate does not have a gap, and it is completely attached to the wall.
      • If any gap is detected, push the plate to the wall and continue to tighten the screws until the gap completely closes.
      Ask FixBot
2 other people completed this guide.
Author
with
Leydi Navarrete
197 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 11
Past 7 Days: 69
Past 30 Days: 275
All Time: 4,361
