Wahl Professional Designer Power Cord Replacement
    1. Wahl Professional Designer Power Cord Replacement, Power Cord: step 1, image 1 of 2 Wahl Professional Designer Power Cord Replacement, Power Cord: step 1, image 2 of 2
      • Unscrew the 12 mm Phillips head screws located at the top of the cover and at the bottom two corners, using a Phillips #1 Screwdriver.
      Ask FixBot
    2. Wahl Professional Designer Power Cord Replacement: step 2, image 1 of 3 Wahl Professional Designer Power Cord Replacement: step 2, image 2 of 3 Wahl Professional Designer Power Cord Replacement: step 2, image 3 of 3
      • Remove the cover from the device.
      Ask FixBot
    3. Wahl Professional Designer Power Cord Replacement: step 3, image 1 of 3 Wahl Professional Designer Power Cord Replacement: step 3, image 2 of 3 Wahl Professional Designer Power Cord Replacement: step 3, image 3 of 3
      • Unscrew the black 5.556 mm Phillip head screw on the power switch, closest to the power cord with a Phillips #0 Screwdriver.
      Ask FixBot
    4. Wahl Professional Designer Power Cord Replacement: step 4, image 1 of 2 Wahl Professional Designer Power Cord Replacement: step 4, image 2 of 2
      • Gently remove the black wire connected to the black screw.
      Ask FixBot
    5. Wahl Professional Designer Power Cord Replacement: step 5, image 1 of 3 Wahl Professional Designer Power Cord Replacement: step 5, image 2 of 3 Wahl Professional Designer Power Cord Replacement: step 5, image 3 of 3
      • Remove the white wire connected to the power cord and the motor by grabbing the white wire firmly on both sides near the motor mounting and wiggling until release.
      Ask FixBot
    6. Wahl Professional Designer Power Cord Replacement: step 6, image 1 of 2 Wahl Professional Designer Power Cord Replacement: step 6, image 2 of 2
      • Remove the power cord from its mount at the bottom of the device.
      Ask FixBot
Sophia Swearengin
814 Reputation
5 Guides authored
USF Tampa, Team S14-G5, Boczar Fall 2017 Member of USF Tampa, Team S14-G5, Boczar Fall 2017
USFT-BOCZAR-F17S14G5
2 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 33
Past 30 Days: 56
All Time: 824
