Wahl Lithium Ion Trimmer Slide switch Replacement
Views: 4.1K
View statistics:
Past 24 Hours:
4
Past 7 Days:
30
Past 30 Days:
106
All Time:
4,071
Comments: 1
1 guide comment.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Grammar Police
Embrace your inner English teacher and help improve this guide's grammar!
Confusing Text
Some of this guide's text is confusing, duplicated, or off-topic. Clarify it by editing!
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Missing Prerequisites
This guide is missing information on how to start the process. Make a prerequisite guide!
Missing Details
Some of this guide's details are missing. Help users by adding tools, difficulty, or time.
Introduction
Go to step 1 ↓
This guide will teach you how to replace the power switch on your razor instead of going and buying a new razor all together. This switch has a plastic mechanism that is connected to the slider from the inside. The plastic switch is in between the battery and motor that controls power. This switch could get jammed or broken off.
    1. Wahl Lithium Ion Trimmer  Slide switch Replacement, Slide switch: step 1, image 1 of 1
      • Start at the last step of the disassembly guide.
      Ask FixBot
    2. Wahl Lithium Ion Trimmer  Slide switch Replacement: step 2, image 1 of 1
      • remove the inside on the razor which includes the chip set, battery, motor and switch.
      Ask FixBot
    3. Wahl Lithium Ion Trimmer  Slide switch Replacement: step 3, image 1 of 1
      • focus on the chip set and the white piece on top. The white piece is the switch that turns the razor on and off.
      Ask FixBot
    4. Wahl Lithium Ion Trimmer  Slide switch Replacement: step 4, image 1 of 1
      • Remove the white piece. Be careful doing so because the chip set is delicate and breaking that would result in replacing that as well.
      Ask FixBot
    5. Wahl Lithium Ion Trimmer  Slide switch Replacement: step 5, image 1 of 1
      • Upon removing the switch, exchange the broken part with the new one that you bought and replace it. Once installed put the razor back together and now you will be able to turn the razor on and off.
      Ask FixBot
nathan
1,440 Reputation
6 Guides authored
1 Guide Comment
Where can you source this part from?
John - Reply Share
Past 24 Hours: 4
Past 7 Days: 30
Past 30 Days: 106
All Time: 4,071
