Wahl Chrome Pro Power Cord Replacement
    1. Wahl Chrome Pro Power Cord Replacement, Case: step 1, image 1 of 1
      • Remove the two 5.0 mm JIS #1 screws to loosen the cutting blades.
      • Make sure your device is not connected to power before you begin.
      Ask FixBot
    2. Wahl Chrome Pro Power Cord Replacement: step 2, image 1 of 1
      • Lift the bottom blade straight up from the device body to remove it.
      Ask FixBot
    3. Wahl Chrome Pro Power Cord Replacement: step 3, image 1 of 1
      • Remove the three 9.0 mm JIS #1 screws attaching the base of the blade assembly to the body.
      Ask FixBot
    4. Wahl Chrome Pro Power Cord Replacement: step 4, image 1 of 1
      • Lift the base of blade assembly straight up off of the body.
      Ask FixBot
    5. Wahl Chrome Pro Power Cord Replacement: step 5, image 1 of 1
      • Remove the two 12.0 mm JIS #1 screws on the back of the device body.
      Ask FixBot
    6. Wahl Chrome Pro Power Cord Replacement: step 6, image 1 of 1
      • Remove the 13.0 mm Phillips #2 screw on the side of the device body.
      • This screw is located on the opposite side of the body from the switch.
      Ask FixBot
    7. Wahl Chrome Pro Power Cord Replacement: step 7, image 1 of 1
      Tool used on this step:
      Buy
      • Remove the spring on the side of the body using tweezers.
      Ask FixBot
    8. Wahl Chrome Pro Power Cord Replacement: step 8, image 1 of 1
      • Pry the body case off of the device using a spudger.
      Ask FixBot
    1. Wahl Chrome Pro Power Cord Replacement, Power Cord: step 9, image 1 of 2 Wahl Chrome Pro Power Cord Replacement, Power Cord: step 9, image 2 of 2
      • Remove one 7.5 mm JIS #1 screw from the switch base.
      Ask FixBot
    2. Wahl Chrome Pro Power Cord Replacement: step 10, image 1 of 1
      • Unplug the cord terminal from the motor connector.
      Ask FixBot
    3. Wahl Chrome Pro Power Cord Replacement: step 11, image 1 of 1
      • Remove the cord from the device base by pulling gently.
      Ask FixBot
Manuel Salazar M.
113 Reputation
1 Guide authored
IUPUI, Team S7-G3, Baechle Fall 2017 Member of IUPUI, Team S7-G3, Baechle Fall 2017
IUPUI-BAECHLE-F17S7G3
3 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 8
Past 7 Days: 19
Past 30 Days: 40
All Time: 1,398
