Wahl Chrome Pro Power Case Guide
Views: 1.8K
View statistics:
Past 24 Hours:
3
Past 7 Days:
14
Past 30 Days:
113
All Time:
1,765
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
The Wahl Chrome Pro components are protected by an outer plastic body held together by several screws. This guide provides information on how to remove the outer protective case to access various internal components.
Tools
    1. Wahl Chrome Pro Power Case Guide, Case: step 1, image 1 of 1
      • Remove the two 5.0 mm JIS #1 screws to loosen the cutting blades.
      • Make sure your device is not connected to power before you begin.
      Ask FixBot
    2. Wahl Chrome Pro Power Case Guide: step 2, image 1 of 1
      • Lift the bottom blade straight up from the device body to remove it.
      Ask FixBot
    3. Wahl Chrome Pro Power Case Guide: step 3, image 1 of 1
      • Remove the three 9.0 mm JIS #1 screws attaching the base of the blade assembly to the body.
      Ask FixBot
    4. Wahl Chrome Pro Power Case Guide: step 4, image 1 of 1
      • Lift the base of blade assembly straight up off of the body.
      Ask FixBot
    5. Wahl Chrome Pro Power Case Guide: step 5, image 1 of 1
      • Remove the two 12.0 mm JIS #1 screws on the back of the device body.
      Ask FixBot
    6. Wahl Chrome Pro Power Case Guide: step 6, image 1 of 1
      • Remove the 13.0 mm Phillips #2 screw on the side of the device body.
      • This screw is located on the opposite side of the body from the switch.
      Ask FixBot
    7. Wahl Chrome Pro Power Case Guide: step 7, image 1 of 1
      Tool used on this step:
      Buy
      • Remove the spring on the side of the body using tweezers.
      Ask FixBot
    8. Wahl Chrome Pro Power Case Guide: step 8, image 1 of 1
      • Pry the body case off of the device using a spudger.
      Ask FixBot
2 other people completed this guide.
Ashley Dale
354 Reputation
2 Guides authored
IUPUI, Team S7-G3, Baechle Fall 2017 Member of IUPUI, Team S7-G3, Baechle Fall 2017
IUPUI-BAECHLE-F17S7G3
3 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 14
Past 30 Days: 113
All Time: 1,765
