Up to 20% off select tools
Wacom Intuos4 Touch Ring Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
16
Past 30 Days:
65
All Time:
731
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
The Wacom Intuos4s touch ring is useful for navigating your computer quickly. If the keys become loose, damaged or otherwise work improperly this guide will help you fix them.
This guide was created with a model PTK-640 Wacom Intuos4. Different models may vary in design.
    1. Wacom Intuos4 Touch Ring Replacement, Casing: step 1, image 1 of 3 Wacom Intuos4 Touch Ring Replacement, Casing: step 1, image 2 of 3 Wacom Intuos4 Touch Ring Replacement, Casing: step 1, image 3 of 3
      • Flip device on its back and remove all fourteen 7.1 mm screws using a Phillips #1 screwdriver.
      • There is a single screw located under each of the rubber leg pieces. Use a shimmy tool to remove these pieces to access the screws.
      Ask FixBot
    2. Wacom Intuos4 Touch Ring Replacement: step 2, image 1 of 2 Wacom Intuos4 Touch Ring Replacement: step 2, image 2 of 2
      • Lift the screen's foam backing connecting the motherboard/drawing board to the two smaller express-key boards, placing it onto the motherboard.
      • Separate the outer casing from the rest of the tablet.
      Ask FixBot
    1. Wacom Intuos4 Touch Ring Replacement, Motherboard: step 3, image 1 of 2 Wacom Intuos4 Touch Ring Replacement, Motherboard: step 3, image 2 of 2
      Tool used on this step:
      Buy
      • Using tweezers, remove the yellow tape covering the three cable connectors.
      Ask FixBot
    2. Wacom Intuos4 Touch Ring Replacement: step 4, image 1 of 2 Wacom Intuos4 Touch Ring Replacement: step 4, image 2 of 2
      • Lift the black plastic clip holding the flat wire to the connector with either tweezers or an iFixit opening tool.
      • Pull on the white plastic tab to disconnect the flat wire.
      Ask FixBot
    3. Wacom Intuos4 Touch Ring Replacement: step 5, image 1 of 2 Wacom Intuos4 Touch Ring Replacement: step 5, image 2 of 2
      • Carefully remove the motherboard from the casing.
      • If you're having trouble, don't force it. Make sure all cables are disconnected and all screws are removed.
      Ask FixBot
    1. Wacom Intuos4 Touch Ring Replacement, Touch Ring: step 6, image 1 of 2 Wacom Intuos4 Touch Ring Replacement, Touch Ring: step 6, image 2 of 2
      • Remove the plastic tracking ball by lifting it up and out of its slot.
      Ask FixBot
    2. Wacom Intuos4 Touch Ring Replacement: step 7, image 1 of 1
      • Use an iFixit opening tool to gently lift the circuit board from the slot.
      • If the touch ring doesn't come out immediately, do not force it or you may cause damage to the device. If it is difficult to remove, heat the front face of the touch ring to loosen the glue that holds it in.
      Ask FixBot
Author
with
Lillian Avery
91 Reputation
1 Guide authored
UMass Dartmouth, Team 3-6, Botvin Fall 2022 Member of UMass Dartmouth, Team 3-6, Botvin Fall 2022
UMASSD-BOTVIN-F22S3G6
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 65
All Time: 731
