Wacom Intuos4 Motherboard Replacement
    1. Wacom Intuos4 Motherboard Replacement, Casing: step 1, image 1 of 3 Wacom Intuos4 Motherboard Replacement, Casing: step 1, image 2 of 3 Wacom Intuos4 Motherboard Replacement, Casing: step 1, image 3 of 3
      • Flip device on its back and remove all fourteen 7.1 mm screws using a Phillips #1 screwdriver.
      • There is a single screw located under each of the rubber leg pieces. Use a shimmy tool to remove these pieces to access the screws.
      Ask FixBot
    2. Wacom Intuos4 Motherboard Replacement: step 2, image 1 of 2 Wacom Intuos4 Motherboard Replacement: step 2, image 2 of 2
      • Lift the screen's foam backing connecting the motherboard/drawing board to the two smaller express-key boards, placing it onto the motherboard.
      • Separate the outer casing from the rest of the tablet.
      Ask FixBot
    1. Wacom Intuos4 Motherboard Replacement, Motherboard: step 3, image 1 of 2 Wacom Intuos4 Motherboard Replacement, Motherboard: step 3, image 2 of 2
      Tool used on this step:
      Buy
      • Using tweezers, remove the yellow tape covering the three cable connectors.
      Ask FixBot
    2. Wacom Intuos4 Motherboard Replacement: step 4, image 1 of 2 Wacom Intuos4 Motherboard Replacement: step 4, image 2 of 2
      • Lift the black plastic clip holding the flat wire to the connector with either tweezers or an iFixit opening tool.
      • Pull on the white plastic tab to disconnect the flat wire.
      Ask FixBot
    3. Wacom Intuos4 Motherboard Replacement: step 5, image 1 of 2 Wacom Intuos4 Motherboard Replacement: step 5, image 2 of 2
      • Carefully remove the motherboard from the casing.
      • If you're having trouble, don't force it. Make sure all cables are disconnected and all screws are removed.
      Ask FixBot
Jack Palmgren
234 Reputation
2 Guides authored
UMass Dartmouth, Team 3-6, Botvin Fall 2022 Member of UMass Dartmouth, Team 3-6, Botvin Fall 2022
UMASSD-BOTVIN-F22S3G6
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 33
All Time: 828
