Wacom Intuos4 Foam Safety Pad Replacement
  1. Wacom Intuos4 Foam Safety Pad Replacement, Casing: step 1, image 1 of 3 Wacom Intuos4 Foam Safety Pad Replacement, Casing: step 1, image 2 of 3 Wacom Intuos4 Foam Safety Pad Replacement, Casing: step 1, image 3 of 3
    • Flip device on its back and remove all fourteen 7.1 mm screws using a Phillips #1 screwdriver.
    • There is a single screw located under each of the rubber leg pieces. Use a shimmy tool to remove these pieces to access the screws.
    Ask FixBot
  2. Wacom Intuos4 Foam Safety Pad Replacement: step 2, image 1 of 2 Wacom Intuos4 Foam Safety Pad Replacement: step 2, image 2 of 2
    • Lift the screen's foam backing connecting the motherboard/drawing board to the two smaller express-key boards, placing it onto the motherboard.
    • Separate the outer casing from the rest of the tablet.
    Ask FixBot
  3. Wacom Intuos4 Foam Safety Pad Replacement, Foam Safety Pad: step 3, image 1 of 1
    • Use a spudger to safely remove the white and sliver pad without applying enough pressure to scratch the motherboard.
    Ask FixBot
Aidan Sullivan
293 Reputation
2 Guides authored
UMass Dartmouth, Team 3-6, Botvin Fall 2022 Member of UMass Dartmouth, Team 3-6, Botvin Fall 2022
UMASSD-BOTVIN-F22S3G6
4 Members
10 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 28
All Time: 354
