Up to 20% off select tools
Wacom Intuos4 Casing Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
13
Past 30 Days:
76
All Time:
982
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 minutes
Difficulty: Very easy
Tools
Introduction
Go to step 1 ↓
Use this guide to replace the casing on a Wacom Intuos4.
If your case is cracked or bent, then your device's internals are at risk of breaking. It's best to keep your device's case in good condition. If you're still unsure if your case needs replacement view the Wacom Intuos4 troubleshooting page on bent casing: Wacom Intuos4 Troubleshooting.
This guide was created with a model PTK-640 Wacom Intuos4. Different models may vary in design.
    1. Wacom Intuos4 Casing Replacement, Casing: step 1, image 1 of 3 Wacom Intuos4 Casing Replacement, Casing: step 1, image 2 of 3 Wacom Intuos4 Casing Replacement, Casing: step 1, image 3 of 3
      • Flip device on its back and remove all fourteen 7.1 mm screws using a Phillips #1 screwdriver.
      • There is a single screw located under each of the rubber leg pieces. Use a shimmy tool to remove these pieces to access the screws.
      Ask FixBot
    2. Wacom Intuos4 Casing Replacement: step 2, image 1 of 2 Wacom Intuos4 Casing Replacement: step 2, image 2 of 2
      • Lift the screen's foam backing connecting the motherboard/drawing board to the two smaller express-key boards, placing it onto the motherboard.
      • Separate the outer casing from the rest of the tablet.
      Ask FixBot
Author
with
Jack Palmgren
234 Reputation
2 Guides authored
UMass Dartmouth, Team 3-6, Botvin Fall 2022 Member of UMass Dartmouth, Team 3-6, Botvin Fall 2022
UMASSD-BOTVIN-F22S3G6
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 76
All Time: 982
