Wacom Intuos Pro Motherboard Replacement
    1. Wacom Intuos Pro Motherboard Replacement, Battery: step 1, image 1 of 3 Wacom Intuos Pro Motherboard Replacement, Battery: step 1, image 2 of 3 Wacom Intuos Pro Motherboard Replacement, Battery: step 1, image 3 of 3
      • Orient the device so the bottom casing is facing upwards.
      • Use your fingers to gently pull on the rubber covers on the bottom of the device to remove them.
      Ask FixBot
    2. Wacom Intuos Pro Motherboard Replacement: step 2, image 1 of 3 Wacom Intuos Pro Motherboard Replacement: step 2, image 2 of 3 Wacom Intuos Pro Motherboard Replacement: step 2, image 3 of 3
      • Remove the four 4mm screws from underneath the rubber feet using a Phillips #00 screwdriver.
      • The screws are located 40mm in from the edge, so it not necessary to completely remove the rubber if you prefer not to.
      Ask FixBot
    3. Wacom Intuos Pro Motherboard Replacement: step 3, image 1 of 2 Wacom Intuos Pro Motherboard Replacement: step 3, image 2 of 2
      • Insert the iFixit Opening Tool between the front and back cover of the device in order to snap and separate the type locks from around the edges.
      • Use the iFixit Opening Tool all the way around the edges until all the snaps have been released.
      • While going around the edges, make sure you have a tight grip to keep the device from sliding.
      Ask FixBot
    4. Wacom Intuos Pro Motherboard Replacement: step 4, image 1 of 2 Wacom Intuos Pro Motherboard Replacement: step 4, image 2 of 2
      • Remove the case backing from the rear of the device with your hands so the internal components are exposed.
      Ask FixBot
    5. Wacom Intuos Pro Motherboard Replacement: step 5, image 1 of 2 Wacom Intuos Pro Motherboard Replacement: step 5, image 2 of 2
      • If not already done, desolder the three colored cables that connect the battery to the motherboard.
      • After desoldering the battery, carefully remove it.
      • Be careful when handling the soldering iron given it's high operating temperature and the possibility for it to damage other components.
      • For help soldering, check out our How to Solder and Desolder Connections guide.
      Ask FixBot
    1. Wacom Intuos Pro Motherboard Replacement, Motherboard: step 6, image 1 of 1
      • Gently pull the blue tabs on the four ribbon cables from the ZIF connectors on the motherboard.
      Ask FixBot
    2. Wacom Intuos Pro Motherboard Replacement: step 7, image 1 of 1
      • Remove the 4.5mm screw holding down the motherboard using a Phillips #00 screwdriver.
      Ask FixBot
    3. Wacom Intuos Pro Motherboard Replacement: step 8, image 1 of 1
      • Remove all three ribbon cables by gently pulling on their respective ''Black" and "Blue" tabs.
      Ask FixBot
    4. Wacom Intuos Pro Motherboard Replacement: step 9, image 1 of 1
      • Gently remove the motherboard from the case.
      Ask FixBot
1 Guide Comment
i am having a problem with my wacom Intuos pro m 2017, its a Bluetooth issue with the tablet itself self so i am planning to change the Bluetooth connector inside the tablet there is no documentation or anything about the exact device that i should use.
tahsen alboune - Reply Share
Past 24 Hours: 0
Past 7 Days: 21
Past 30 Days: 67
All Time: 2,628
