Wacom Intuos CTL4100 Battery Replacement
Views: 7.5K
View statistics:
Past 24 Hours:
11
Past 7 Days:
44
Past 30 Days:
231
All Time:
7,471
Comments: 6
6 guide comments.
Go to guide comments
Completed: 7
7 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 - 30 minutes
Difficulty: Moderate
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓
Battery capacities degrade over time, reducing battery life. If the battery is not charging or the battery lifespan is not as long as it used to be, you might need to replace your battery. This guide will show you how to replace the battery of your Wacom Intuos CTL4100.
If your battery is swollen take appropriate precautions. Be sure to power off your device and unplug from any external power prior to beginning the repair.
Tools
    1. Wacom Intuos CTL4100 Battery Replacement, Battery: step 1, image 1 of 3 Wacom Intuos CTL4100 Battery Replacement, Battery: step 1, image 2 of 3 Wacom Intuos CTL4100 Battery Replacement, Battery: step 1, image 3 of 3
      • Flip the tablet over so the bottom case faces upwards.
      • Remove the rubber pads on the corners by pulling them up with your fingers.
      Ask FixBot
    2. Wacom Intuos CTL4100 Battery Replacement: step 2, image 1 of 3 Wacom Intuos CTL4100 Battery Replacement: step 2, image 2 of 3 Wacom Intuos CTL4100 Battery Replacement: step 2, image 3 of 3
      Ask FixBot
    3. Wacom Intuos CTL4100 Battery Replacement: step 3, image 1 of 3 Wacom Intuos CTL4100 Battery Replacement: step 3, image 2 of 3 Wacom Intuos CTL4100 Battery Replacement: step 3, image 3 of 3
      • Insert a plastic opening pick between the front and back case to unclip the clips that hold the cases together.
      • Slide your plastic opening pick around the sides until all clips are unclipped.
      Ask FixBot
    4. Wacom Intuos CTL4100 Battery Replacement: step 4, image 1 of 2 Wacom Intuos CTL4100 Battery Replacement: step 4, image 2 of 2
      • Lift the bottom case to separate the top and bottom case
      • When you see the internal components, set aside the bottom case.
      Ask FixBot
    5. Wacom Intuos CTL4100 Battery Replacement: step 5, image 1 of 2 Wacom Intuos CTL4100 Battery Replacement: step 5, image 2 of 2
      • Remove the yellow tape that is on top of the battery wires.
      • When the battery wires under the tape are exposed, stick the yellow tape just above the battery wires.
      Ask FixBot
    6. Wacom Intuos CTL4100 Battery Replacement: step 6, image 1 of 2 Wacom Intuos CTL4100 Battery Replacement: step 6, image 2 of 2
      • Gently pull up the battery wire pin with your fingers to disconnect the pin from the motherboard.
      Ask FixBot
    7. Wacom Intuos CTL4100 Battery Replacement: step 7, image 1 of 2 Wacom Intuos CTL4100 Battery Replacement: step 7, image 2 of 2
      • Remove the battery by lifting the battery up with your fingers.
      Ask FixBot
    8. Wacom Intuos CTL4100 Battery Replacement: step 8, image 1 of 1
      • Place the new battery on the area you removed the battery.
      Ask FixBot
    9. Wacom Intuos CTL4100 Battery Replacement: step 9, image 1 of 2 Wacom Intuos CTL4100 Battery Replacement: step 9, image 2 of 2
      • Gently connect the battery wire pin to the motherboard.
      Ask FixBot
    10. Wacom Intuos CTL4100 Battery Replacement: step 10, image 1 of 2 Wacom Intuos CTL4100 Battery Replacement: step 10, image 2 of 2
      • Reapply the tape you put above the battery wires.
      Ask FixBot
To reassemble your device, follow step 4 in reverse order.
7 other people completed this guide.
Marcus Sisouphanh
370 Reputation
1 Guide authored
6 Guide Comments
Where did you get the replacement battery?
David VeLar - Reply Share
Will it work without a battery?
Jordi Prats - Reply Share
Answering my own question, yes, it works without a battery. It will popup a notification of low battery sometimes, and obviously it won't work wirelessly.
Ah, and I tried this with a CTL6100 tablet, so this guide is valid for this model as well (a bit larger but mostly identical inside).
Did the light go on on the 6100 as soon as you plugged it in?
Kubbies - Reply Share
Where did you get the battery pls?
Taaa - Reply Share
Past 24 Hours: 11
Past 7 Days: 44
Past 30 Days: 231
All Time: 7,471
