Wacom Cintiq 24HD Stand Replacement
  1. Wacom Cintiq 24HD Stand Replacement, Stand: step 1, image 1 of 1
    • Unplug any cables from the USB, power, display or DVI-D ports by gripping the cord by the connector and pulling straight out of the port.
    • Unplugging the cables by pulling on the cord or pulling at an angle can damage the cable or connector.
    Ask FixBot
  2. Wacom Cintiq 24HD Stand Replacement: step 2, image 1 of 3 Wacom Cintiq 24HD Stand Replacement: step 2, image 2 of 3 Wacom Cintiq 24HD Stand Replacement: step 2, image 3 of 3
    • Place the device screen down on a flat surface.
    • Remove eight 10mm Phillips #2 screws (four on each leg of the stand) by turning the screwdriver counterclockwise.
    Ask FixBot
  3. Wacom Cintiq 24HD Stand Replacement: step 3, image 1 of 1
    • Lift the stand up and away from the rest of the device so the legs separate from the mounting plate.
    Ask FixBot
Andrew Fleming
408 Reputation
3 Guides authored
Cal Poly, Team S15-G3, White Fall 2018 Member of Cal Poly, Team S15-G3, White Fall 2018
CPSU-WHITE-F18S15G3
4 Members
18 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 16
Past 30 Days: 76
All Time: 2,850
