Wacom Cintiq 24HD Power Port Replacement
    1. Wacom Cintiq 24HD Power Port Replacement, Stand: step 1, image 1 of 1
      • Unplug any cables from the USB, power, display or DVI-D ports by gripping the cord by the connector and pulling straight out of the port.
      • Unplugging the cables by pulling on the cord or pulling at an angle can damage the cable or connector.
      Ask FixBot
    2. Wacom Cintiq 24HD Power Port Replacement: step 2, image 1 of 3 Wacom Cintiq 24HD Power Port Replacement: step 2, image 2 of 3 Wacom Cintiq 24HD Power Port Replacement: step 2, image 3 of 3
      • Place the device screen down on a flat surface.
      • Remove eight 10mm Phillips #2 screws (four on each leg of the stand) by turning the screwdriver counterclockwise.
      Ask FixBot
    3. Wacom Cintiq 24HD Power Port Replacement: step 3, image 1 of 1
      • Lift the stand up and away from the rest of the device so the legs separate from the mounting plate.
      Ask FixBot
    1. Wacom Cintiq 24HD Power Port Replacement, Back Panel: step 4, image 1 of 3 Wacom Cintiq 24HD Power Port Replacement, Back Panel: step 4, image 2 of 3 Wacom Cintiq 24HD Power Port Replacement, Back Panel: step 4, image 3 of 3
      • Remove eighteen 10.2mm Phillips #1 screws from the perimeter of the back panel by turning the screwdriver counterclockwise.
      • Remove one 11.9mm Phillips #1 screw from the center of the back panel.
      • Remove two 10.2mm Phillips #1 screws from underneath hinged panels in the bottom right and left corners.
      • Our device does not include the cover panels for the USB, DVI-D, and power ports. You must first remove these cover panels shown in green in order to remove the back panel.
      Ask FixBot
    2. Wacom Cintiq 24HD Power Port Replacement: step 5, image 1 of 2 Wacom Cintiq 24HD Power Port Replacement: step 5, image 2 of 2
      • Lift the back panel up by a corner and insert a plastic opening tool in the gap.
      • Slide the tool along the gap around the perimeter of the device while lifting to unlatch the back panel.
      • The latches on the back panel will make loud clicking noises when opening.
      • Remove the panel by lifting it up and off of the device.
      Ask FixBot
    1. Wacom Cintiq 24HD Power Port Replacement, Interior Metal Plate: step 6, image 1 of 3 Wacom Cintiq 24HD Power Port Replacement, Interior Metal Plate: step 6, image 2 of 3 Wacom Cintiq 24HD Power Port Replacement, Interior Metal Plate: step 6, image 3 of 3
      • Detach the small black wire connecting the back metal plate to the USB video port by removing the one 8 mm Phillips #2 screw from the back metal plate and turning the screwdriver counterclockwise.
      Ask FixBot
    2. Wacom Cintiq 24HD Power Port Replacement: step 7, image 1 of 3 Wacom Cintiq 24HD Power Port Replacement: step 7, image 2 of 3 Wacom Cintiq 24HD Power Port Replacement: step 7, image 3 of 3
      • Remove the two 8 mm Phillips #2 screws from the metal button plate by rotating the screwdriver counterclockwise.
      • Remove the metal button plate from the back metal plate.
      Ask FixBot
    3. Wacom Cintiq 24HD Power Port Replacement: step 8, image 1 of 3 Wacom Cintiq 24HD Power Port Replacement: step 8, image 2 of 3 Wacom Cintiq 24HD Power Port Replacement: step 8, image 3 of 3
      • Remove the button wires from the support clip by pushing down on the clip.
      • Detach the button wires from the button board by pulling the button wires away from the board.
      • Place the button board back in to the device.
      Ask FixBot
    4. Wacom Cintiq 24HD Power Port Replacement: step 9, image 1 of 3 Wacom Cintiq 24HD Power Port Replacement: step 9, image 2 of 3 Wacom Cintiq 24HD Power Port Replacement: step 9, image 3 of 3
      • Remove the eight (four on each plate) 10.2mm Phillips #2 screws with locking washers from the metal mounting plates by rotating the screwdriver counterclockwise.
      • Remove the two metal mounting plates.
      Ask FixBot
    5. Wacom Cintiq 24HD Power Port Replacement: step 10, image 1 of 3 Wacom Cintiq 24HD Power Port Replacement: step 10, image 2 of 3 Wacom Cintiq 24HD Power Port Replacement: step 10, image 3 of 3
      • Remove the sixteen 8 mm Phillips #2 screws with flanges from the horizontal side of the plate by turning the screwdriver counterclockwise.
      • Remove the ten 8 mm Phillips #2 screws with flanges from the vertical sides of the plate by turning the screwdriver counterclockwise.
      Ask FixBot
    6. Wacom Cintiq 24HD Power Port Replacement: step 11, image 1 of 1
      • Remove the back metal plate by lifting up along one edge , then lifting the plate off and away from the device.
      Ask FixBot
    1. Wacom Cintiq 24HD Power Port Replacement, Power Port: step 12, image 1 of 1
      • Remove the two 7.8mm Phillips #2 screws from the right back panel connected to the power port by turning the screwdriver counterclockwise.
      Ask FixBot
    2. Wacom Cintiq 24HD Power Port Replacement: step 13, image 1 of 2 Wacom Cintiq 24HD Power Port Replacement: step 13, image 2 of 2
      • Lift the power port and attached daughterboard out of the device.
      • Remove the wires from the daughterboard.
      • Pull gently on the wires when removing from the daughterboard to prevent any tearing.
      Ask FixBot
    3. Wacom Cintiq 24HD Power Port Replacement: step 14, image 1 of 2 Wacom Cintiq 24HD Power Port Replacement: step 14, image 2 of 2
      • Remove the two 8 mm Phillips #2 screws from the daughterboard by turning the screwdriver counterclockwise.
      • Detach the metal cover from the power port.
      Ask FixBot
    4. Wacom Cintiq 24HD Power Port Replacement: step 15, image 1 of 2 Wacom Cintiq 24HD Power Port Replacement: step 15, image 2 of 2
      • Desolder the connections the power port connections using a soldering iron.
      • Remove the power port from the daughterboard by lifting it off.
      • iFixit has a guide to soldering which you can find here.
      Ask FixBot
3 other people completed this guide.
Sydney Hosokawa
290 Reputation
2 Guides authored
Cal Poly, Team S15-G3, White Fall 2018 Member of Cal Poly, Team S15-G3, White Fall 2018
CPSU-WHITE-F18S15G3
4 Members
18 Guides authored
8 Guide Comments
could you give the part, so i can buy it please
jmcl21 - Reply Share
My 24 HD blue power light comes on and off about once a second, you can hear the fan start and stop. Is a faulty power board the reason or is it the ps block ?
Thomas McGarrity - Reply Share
Hi,
Can you please tell me whrere I could buy the power port? I'm searching for several days and I couldn't find it.
tonet - Reply Share
Is there any where I can get this part the circuit board is damaged
Brian O'Kelly - Reply Share
any information regarding where to buy this component
Mario Romario - Reply Share
Past 24 Hours: 5
Past 7 Days: 29
Past 30 Days: 69
All Time: 4,304
