Wacom Cintiq 24HD Power Button Replacement
    1. Wacom Cintiq 24HD Power Button Replacement, Stand: step 1, image 1 of 1
      • Unplug any cables from the USB, power, display or DVI-D ports by gripping the cord by the connector and pulling straight out of the port.
      • Unplugging the cables by pulling on the cord or pulling at an angle can damage the cable or connector.
      Ask FixBot
    2. Wacom Cintiq 24HD Power Button Replacement: step 2, image 1 of 3 Wacom Cintiq 24HD Power Button Replacement: step 2, image 2 of 3 Wacom Cintiq 24HD Power Button Replacement: step 2, image 3 of 3
      • Place the device screen down on a flat surface.
      • Remove eight 10mm Phillips #2 screws (four on each leg of the stand) by turning the screwdriver counterclockwise.
      Ask FixBot
    3. Wacom Cintiq 24HD Power Button Replacement: step 3, image 1 of 1
      • Lift the stand up and away from the rest of the device so the legs separate from the mounting plate.
      Ask FixBot
    1. Wacom Cintiq 24HD Power Button Replacement, Back Panel: step 4, image 1 of 3 Wacom Cintiq 24HD Power Button Replacement, Back Panel: step 4, image 2 of 3 Wacom Cintiq 24HD Power Button Replacement, Back Panel: step 4, image 3 of 3
      • Remove eighteen 10.2mm Phillips #1 screws from the perimeter of the back panel by turning the screwdriver counterclockwise.
      • Remove one 11.9mm Phillips #1 screw from the center of the back panel.
      • Remove two 10.2mm Phillips #1 screws from underneath hinged panels in the bottom right and left corners.
      • Our device does not include the cover panels for the USB, DVI-D, and power ports. You must first remove these cover panels shown in green in order to remove the back panel.
      Ask FixBot
    2. Wacom Cintiq 24HD Power Button Replacement: step 5, image 1 of 2 Wacom Cintiq 24HD Power Button Replacement: step 5, image 2 of 2
      • Lift the back panel up by a corner and insert a plastic opening tool in the gap.
      • Slide the tool along the gap around the perimeter of the device while lifting to unlatch the back panel.
      • The latches on the back panel will make loud clicking noises when opening.
      • Remove the panel by lifting it up and off of the device.
      Ask FixBot
    1. Wacom Cintiq 24HD Power Button Replacement, Power Button: step 6, image 1 of 2 Wacom Cintiq 24HD Power Button Replacement, Power Button: step 6, image 2 of 2
      • Remove the rubber cover on the power button by lifting up and off.
      Ask FixBot
    2. Wacom Cintiq 24HD Power Button Replacement: step 7, image 1 of 1
      • Remove the two 9.5mm Phillips #2 screws by turning the screwdriver counterclockwise.
      Ask FixBot
    3. Wacom Cintiq 24HD Power Button Replacement: step 8, image 1 of 2 Wacom Cintiq 24HD Power Button Replacement: step 8, image 2 of 2
      • Remove the cable connected to the button board by pinching close to the connector and pulling the wiring straight out from the port.
      Ask FixBot
2 other people completed this guide.
Jay Sung
499 Reputation
4 Guides authored
Cal Poly, Team S15-G3, White Fall 2018 Member of Cal Poly, Team S15-G3, White Fall 2018
CPSU-WHITE-F18S15G3
4 Members
108 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 12
Past 30 Days: 46
All Time: 2,555
