Wacom Cintiq 24HD Fan Replacement
  1. Wacom Cintiq 24HD Fan Replacement, Stand: step 1, image 1 of 1
    • Unplug any cables from the USB, power, display or DVI-D ports by gripping the cord by the connector and pulling straight out of the port.
    • Unplugging the cables by pulling on the cord or pulling at an angle can damage the cable or connector.
    Ask FixBot
  2. Wacom Cintiq 24HD Fan Replacement: step 2, image 1 of 3 Wacom Cintiq 24HD Fan Replacement: step 2, image 2 of 3 Wacom Cintiq 24HD Fan Replacement: step 2, image 3 of 3
    • Place the device screen down on a flat surface.
    • Remove eight 10mm Phillips #2 screws (four on each leg of the stand) by turning the screwdriver counterclockwise.
    Ask FixBot
  3. Wacom Cintiq 24HD Fan Replacement: step 3, image 1 of 1
    • Lift the stand up and away from the rest of the device so the legs separate from the mounting plate.
    Ask FixBot
  4. Wacom Cintiq 24HD Fan Replacement, Back Panel: step 4, image 1 of 3 Wacom Cintiq 24HD Fan Replacement, Back Panel: step 4, image 2 of 3 Wacom Cintiq 24HD Fan Replacement, Back Panel: step 4, image 3 of 3
    • Remove eighteen 10.2mm Phillips #1 screws from the perimeter of the back panel by turning the screwdriver counterclockwise.
    • Remove one 11.9mm Phillips #1 screw from the center of the back panel.
    • Remove two 10.2mm Phillips #1 screws from underneath hinged panels in the bottom right and left corners.
    • Our device does not include the cover panels for the USB, DVI-D, and power ports. You must first remove these cover panels shown in green in order to remove the back panel.
    Ask FixBot
  5. Wacom Cintiq 24HD Fan Replacement: step 5, image 1 of 2 Wacom Cintiq 24HD Fan Replacement: step 5, image 2 of 2
    • Lift the back panel up by a corner and insert a plastic opening tool in the gap.
    • Slide the tool along the gap around the perimeter of the device while lifting to unlatch the back panel.
    • The latches on the back panel will make loud clicking noises when opening.
    • Remove the panel by lifting it up and off of the device.
    Ask FixBot
  6. Wacom Cintiq 24HD Fan Replacement, Interior Metal Plate: step 6, image 1 of 3 Wacom Cintiq 24HD Fan Replacement, Interior Metal Plate: step 6, image 2 of 3 Wacom Cintiq 24HD Fan Replacement, Interior Metal Plate: step 6, image 3 of 3
    • Detach the small black wire connecting the back metal plate to the USB video port by removing the one 8 mm Phillips #2 screw from the back metal plate and turning the screwdriver counterclockwise.
    Ask FixBot
  7. Wacom Cintiq 24HD Fan Replacement: step 7, image 1 of 3 Wacom Cintiq 24HD Fan Replacement: step 7, image 2 of 3 Wacom Cintiq 24HD Fan Replacement: step 7, image 3 of 3
    • Remove the two 8 mm Phillips #2 screws from the metal button plate by rotating the screwdriver counterclockwise.
    • Remove the metal button plate from the back metal plate.
    Ask FixBot
  8. Wacom Cintiq 24HD Fan Replacement: step 8, image 1 of 3 Wacom Cintiq 24HD Fan Replacement: step 8, image 2 of 3 Wacom Cintiq 24HD Fan Replacement: step 8, image 3 of 3
    • Remove the button wires from the support clip by pushing down on the clip.
    • Detach the button wires from the button board by pulling the button wires away from the board.
    • Place the button board back in to the device.
    Ask FixBot
  9. Wacom Cintiq 24HD Fan Replacement: step 9, image 1 of 3 Wacom Cintiq 24HD Fan Replacement: step 9, image 2 of 3 Wacom Cintiq 24HD Fan Replacement: step 9, image 3 of 3
    • Remove the eight (four on each plate) 10.2mm Phillips #2 screws with locking washers from the metal mounting plates by rotating the screwdriver counterclockwise.
    • Remove the two metal mounting plates.
    Ask FixBot
  10. Wacom Cintiq 24HD Fan Replacement: step 10, image 1 of 3 Wacom Cintiq 24HD Fan Replacement: step 10, image 2 of 3 Wacom Cintiq 24HD Fan Replacement: step 10, image 3 of 3
    • Remove the sixteen 8 mm Phillips #2 screws with flanges from the horizontal side of the plate by turning the screwdriver counterclockwise.
    • Remove the ten 8 mm Phillips #2 screws with flanges from the vertical sides of the plate by turning the screwdriver counterclockwise.
    Ask FixBot
  11. Wacom Cintiq 24HD Fan Replacement: step 11, image 1 of 1
    • Remove the back metal plate by lifting up along one edge , then lifting the plate off and away from the device.
    Ask FixBot
  12. Wacom Cintiq 24HD Fan Replacement, Fan: step 12, image 1 of 2 Wacom Cintiq 24HD Fan Replacement, Fan: step 12, image 2 of 2
    • Remove three 8 mm Phillips #2 screws by turning screwdriver counterclockwise.
    • Each screw has two washers, one flat and one split. The split washer sits between the flat washer and the screw head.
    Ask FixBot
  13. Wacom Cintiq 24HD Fan Replacement: step 13, image 1 of 2 Wacom Cintiq 24HD Fan Replacement: step 13, image 2 of 2
    • Remove the fan wiring from the motherboard by gently pinching close to the connector and pulling outwards.
    • Handle small wires with care to avoid crimping or breaking them.
    • Untangle the fan wiring by pulling it towards the fan and under, over, or around other wiring .
    • You may have to break the black wire tape that holds down the wires to free them.
    Ask FixBot
  14. Wacom Cintiq 24HD Fan Replacement: step 14, image 1 of 1
    • Remove the fan by lifting it up and off of the screw shafts.
    Ask FixBot
2 other people completed this guide.
Andrew Fleming
408 Reputation
3 Guides authored
Cal Poly, Team S15-G3, White Fall 2018 Member of Cal Poly, Team S15-G3, White Fall 2018
CPSU-WHITE-F18S15G3
4 Members
18 Guides authored
5 Guide Comments
Great instructions, but where to buy good replacement fans for this tablet?
tepox80 - Reply Share
so i was only able to find the exact fans only at one place. and it's overseas (china), so the delivery time is about 2 weeks minimum even with expedited shipping.
Fan ID-- SUNON GB1209PKB1-A 12V 2W 4wires Cooling Fan
website i found them : elecok.com
good luck. these instructions were close enough for the pro model of the 27" wacom cintiq.
don't attempt to open this without the Opening Tool or you risk cracking the screen. learned from experience.
Cole Blotcky - Reply Share
Do any fans exist that can replace these very noisy fans and still do a competent job of keeping the equipment cool?
Dave Stephens - Reply Share
I want to disable the fans completely, will the monitor run if I just unplug the connector in step 13?
Franz - Reply Share
Lovely breakdown, thank you.
Looks like there's a big steel casing over everything. I wonder if you could run it without the plastic back cover?. Seems to me the metal inner case would make a nice heat sink but the plastic outer cover traps all the heat...
Cole Blotcky: Your pro 27 must have been within warranty at that point as they were only just out?. Wondered why you fixed it yourself, rather than sending it in? (just interested - thanks)
jim russell - Reply Share
Past 24 Hours: 1
Past 7 Days: 15
Past 30 Days: 58
All Time: 6,553
