Wacom Cintiq 24HD Display Control Buttons Replacement
    1. Wacom Cintiq 24HD Display Control Buttons Replacement, Stand: step 1, image 1 of 1
      • Unplug any cables from the USB, power, display or DVI-D ports by gripping the cord by the connector and pulling straight out of the port.
      • Unplugging the cables by pulling on the cord or pulling at an angle can damage the cable or connector.
      Ask FixBot
    2. Wacom Cintiq 24HD Display Control Buttons Replacement: step 2, image 1 of 3 Wacom Cintiq 24HD Display Control Buttons Replacement: step 2, image 2 of 3 Wacom Cintiq 24HD Display Control Buttons Replacement: step 2, image 3 of 3
      • Place the device screen down on a flat surface.
      • Remove eight 10mm Phillips #2 screws (four on each leg of the stand) by turning the screwdriver counterclockwise.
      Ask FixBot
    3. Wacom Cintiq 24HD Display Control Buttons Replacement: step 3, image 1 of 1
      • Lift the stand up and away from the rest of the device so the legs separate from the mounting plate.
      Ask FixBot
    1. Wacom Cintiq 24HD Display Control Buttons Replacement, Back Panel: step 4, image 1 of 3 Wacom Cintiq 24HD Display Control Buttons Replacement, Back Panel: step 4, image 2 of 3 Wacom Cintiq 24HD Display Control Buttons Replacement, Back Panel: step 4, image 3 of 3
      • Remove eighteen 10.2mm Phillips #1 screws from the perimeter of the back panel by turning the screwdriver counterclockwise.
      • Remove one 11.9mm Phillips #1 screw from the center of the back panel.
      • Remove two 10.2mm Phillips #1 screws from underneath hinged panels in the bottom right and left corners.
      • Our device does not include the cover panels for the USB, DVI-D, and power ports. You must first remove these cover panels shown in green in order to remove the back panel.
      Ask FixBot
    2. Wacom Cintiq 24HD Display Control Buttons Replacement: step 5, image 1 of 2 Wacom Cintiq 24HD Display Control Buttons Replacement: step 5, image 2 of 2
      • Lift the back panel up by a corner and insert a plastic opening tool in the gap.
      • Slide the tool along the gap around the perimeter of the device while lifting to unlatch the back panel.
      • The latches on the back panel will make loud clicking noises when opening.
      • Remove the panel by lifting it up and off of the device.
      Ask FixBot
    1. Wacom Cintiq 24HD Display Control Buttons Replacement, Display Control Buttons: step 6, image 1 of 3 Wacom Cintiq 24HD Display Control Buttons Replacement, Display Control Buttons: step 6, image 2 of 3 Wacom Cintiq 24HD Display Control Buttons Replacement, Display Control Buttons: step 6, image 3 of 3
      • Remove the two 8mm screws from the metal button plate using a Phillips #2 screwdriver and by turning clockwise.
      • Remove metal holding plate by lifting up and off of the button board.
      Ask FixBot
    2. Wacom Cintiq 24HD Display Control Buttons Replacement: step 7, image 1 of 1
      • Remove the button board by pinching the wiring close to the connector and gently pulling straight out from the port.
      Ask FixBot
    3. Wacom Cintiq 24HD Display Control Buttons Replacement: step 8, image 1 of 1
      • Remove the button cover by pushing the buttons out of their holes and pulling the cover up.
      Ask FixBot
2 other people completed this guide.
Jay Sung
499 Reputation
4 Guides authored
Cal Poly, Team S15-G3, White Fall 2018 Member of Cal Poly, Team S15-G3, White Fall 2018
CPSU-WHITE-F18S15G3
4 Members
108 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 31
All Time: 2,042
