Wacom Bamboo Pen And Touch Disassembly
  1. Wacom Bamboo Pen And Touch Disassembly, Wacom Bamboo Pen And Touch Disassembly: step 1, image 1 of 2 Wacom Bamboo Pen And Touch Disassembly, Wacom Bamboo Pen And Touch Disassembly: step 1, image 2 of 2
    • Place the device facing bottom part up.
    • Make sure the working surface won't scratch the surface of the tablet
    Ask FixBot
  2. Wacom Bamboo Pen And Touch Disassembly: step 2, image 1 of 2 Wacom Bamboo Pen And Touch Disassembly: step 2, image 2 of 2
    Tool used on this step:
    Buy
    • Remove 4 rubber feet using a spudger or a pair of tweezers
    • Unscrew 4 #000 Phillips screws
    Ask FixBot
  3. Wacom Bamboo Pen And Touch Disassembly: step 3, image 1 of 1
    • Use spudger or other prying tool to open the tablet.
    • The clips are located all around the perimeter of the tablet
    • The parts inside are attached to the top part of the device
    Ask FixBot
  4. Wacom Bamboo Pen And Touch Disassembly: step 4, image 1 of 1
    • Remove the cable.
    • Do not pull the cable with force - it is soldered to the mainboard
    Ask FixBot
  5. Wacom Bamboo Pen And Touch Disassembly: step 5, image 1 of 1
    • While the pen holder might seem permamently riveted, it can be removed and cleaned
    • Press firmly around the rivets to re-attach it
    Ask FixBot
  6. Wacom Bamboo Pen And Touch Disassembly: step 6, image 1 of 3 Wacom Bamboo Pen And Touch Disassembly: step 6, image 2 of 3 Wacom Bamboo Pen And Touch Disassembly: step 6, image 3 of 3
    • Unclip 3 flex cable connectors
    • The clips are fragile.
    • Unlocked connector's latch is in vertical position.
    • Due to fragiility of flex cables, it's better to remove the adhesive strips only from the mainboard and leave the attached adhesvie strips to the flex cable as is.
    Ask FixBot
  7. Wacom Bamboo Pen And Touch Disassembly: step 7, image 1 of 3 Wacom Bamboo Pen And Touch Disassembly: step 7, image 2 of 3 Wacom Bamboo Pen And Touch Disassembly: step 7, image 3 of 3
    • The mainboard is now loose and can be removed.
    • The mainboard contains a fuse, visible in the second image in the gallery.
    • Replacement of touch digitizer requires removing the top sticker.This procedure is not a part of this guide, and it might permamently destroy the working surface of the tablet.
    • USB Cable is soldered to the mainboard
    Ask FixBot
00004707
1,217 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 39
All Time: 1,251
