Wacker Pump PT3A 2012 Housing Cover O-Rings Replacement
  1. Wacker Pump PT3A 2012 Housing Cover O-Rings Replacement, Disconnect the spark plug wire: step 1, image 1 of 2 Wacker Pump PT3A 2012 Housing Cover O-Rings Replacement, Disconnect the spark plug wire: step 1, image 2 of 2
    • Before you begin, make sure the device is switched off and the engine is cool to the touch.
    • Grab the plastic housing at the end of the spark plug wire.
    • Pull firmly to disconnect the wire from the spark plug.
    Ask FixBot
  2. Wacker Pump PT3A 2012 Housing Cover O-Rings Replacement, Remove the pump housing cover: step 2, image 1 of 3 Wacker Pump PT3A 2012 Housing Cover O-Rings Replacement, Remove the pump housing cover: step 2, image 2 of 3 Wacker Pump PT3A 2012 Housing Cover O-Rings Replacement, Remove the pump housing cover: step 2, image 3 of 3
    • Use the included wrench to loosen the four black knobs securing the pump housing cover.
    • If the wrench is missing, slide a screwdriver shank through the knob and twist to loosen the knobs.
    Ask FixBot
  3. Wacker Pump PT3A 2012 Housing Cover O-Rings Replacement: step 3, image 1 of 3 Wacker Pump PT3A 2012 Housing Cover O-Rings Replacement: step 3, image 2 of 3 Wacker Pump PT3A 2012 Housing Cover O-Rings Replacement: step 3, image 3 of 3
    • Slide the pump housing cover out of the pump and remove it.
    Ask FixBot
  4. Wacker Pump PT3A 2012 Housing Cover O-Rings Replacement, Remove the O-rings: step 4, image 1 of 3 Wacker Pump PT3A 2012 Housing Cover O-Rings Replacement, Remove the O-rings: step 4, image 2 of 3 Wacker Pump PT3A 2012 Housing Cover O-Rings Replacement, Remove the O-rings: step 4, image 3 of 3
    • Use your fingers to peel off and remove the two O-rings from the pump housing cover.
    • The two O-rings are different: the top O-ring is slightly thinner than the bottom O-ring.
    Ask FixBot
Arthur Shi
337,997 Reputation
851 Guides authored
iFixit Member of iFixit
Staff
122 Members
26,593 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 15
Past 30 Days: 57
All Time: 1,081
