Wacker Compactor Plate VP1550AW 2014 V-Belt Replacement
  1. Wacker Compactor Plate VP1550AW 2014 V-Belt Replacement, Safety precautions: step 1, image 1 of 2 Wacker Compactor Plate VP1550AW 2014 V-Belt Replacement, Safety precautions: step 1, image 2 of 2
    • Before you begin, be sure that the engine is powered off and is cool to the touch.
    • Grab the plastic housing at the end of the spark plug wire.
    • Pull firmly to disconnect the wire from the spark plug.
    Ask FixBot
  2. Wacker Compactor Plate VP1550AW 2014 V-Belt Replacement, Loosen the belt guard: step 2, image 1 of 1
    • Use a 1/2" socket and wrench to loosen the two bolts securing the belt guard.
    • The bolts are captive and should not be removed.
    Ask FixBot
  3. Wacker Compactor Plate VP1550AW 2014 V-Belt Replacement, Remove the belt guard: step 3, image 1 of 2 Wacker Compactor Plate VP1550AW 2014 V-Belt Replacement, Remove the belt guard: step 3, image 2 of 2
    • Remove the belt guard.
    Ask FixBot
  4. Wacker Compactor Plate VP1550AW 2014 V-Belt Replacement, Remove the drive belt: step 4, image 1 of 3 Wacker Compactor Plate VP1550AW 2014 V-Belt Replacement, Remove the drive belt: step 4, image 2 of 3 Wacker Compactor Plate VP1550AW 2014 V-Belt Replacement, Remove the drive belt: step 4, image 3 of 3
    • Use scissors or a blade to cut the drive belt.
    • Remove the drive belt.
    Ask FixBot
  5. Wacker Compactor Plate VP1550AW 2014 V-Belt Replacement, Install a replacement belt: step 5, image 1 of 1
    • Loop the replacement belt onto the small pulley.
    Ask FixBot
  6. Wacker Compactor Plate VP1550AW 2014 V-Belt Replacement: step 6, image 1 of 3 Wacker Compactor Plate VP1550AW 2014 V-Belt Replacement: step 6, image 2 of 3 Wacker Compactor Plate VP1550AW 2014 V-Belt Replacement: step 6, image 3 of 3
    • Replacing the belt poses a substantial pinching hazard. Wear safety gloves and be mindful where you position your fingers.
    • Guide the belt over the top of the clutch pulley.
    • Loop the belt underneath the pulley axle.
    • Rotate the pulley slowly and guide the built into the groove.
    • Getting the replacement belt back onto the drive pulley requires considerable strength.
    Ask FixBot
Arthur Shi
343,666 Reputation
915 Guides authored
iFixit Member of iFixit
Staff
123 Members
28,227 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 47
All Time: 3,943
