Wacker Compactor Plate VP1550AW 2014 Shockmount Replacement
    1. Wacker Compactor Plate VP1550AW 2014 Shockmount Replacement, Safety precautions: step 1, image 1 of 2 Wacker Compactor Plate VP1550AW 2014 Shockmount Replacement, Safety precautions: step 1, image 2 of 2
      • Before you begin, be sure that the engine is powered off and is cool to the touch.
      • Grab the plastic housing at the end of the spark plug wire.
      • Pull firmly to disconnect the wire from the spark plug.
      Ask FixBot
    1. Wacker Compactor Plate VP1550AW 2014 Shockmount Replacement, Loosen the handle: step 2, image 1 of 2 Wacker Compactor Plate VP1550AW 2014 Shockmount Replacement, Loosen the handle: step 2, image 2 of 2
      • For ease of access, swing the transport wheels underneath the plate compactor before you begin.
      • Use a 3/4" wrench to remove the two nuts securing the handle.
      • Use your palm to push against the shockmount to prevent it from slipping.
      • Remove the nuts and washers and retain them for reassembly.
      Ask FixBot
    2. Wacker Compactor Plate VP1550AW 2014 Shockmount Replacement, Lower the handle: step 3, image 1 of 3 Wacker Compactor Plate VP1550AW 2014 Shockmount Replacement, Lower the handle: step 3, image 2 of 3 Wacker Compactor Plate VP1550AW 2014 Shockmount Replacement, Lower the handle: step 3, image 3 of 3
      • Tilt the guide handle forward to pivot the shockmount bolts out of the base grooves.
      • Slide the guide handle down enough to access the shockmounts.
      Ask FixBot
    3. Wacker Compactor Plate VP1550AW 2014 Shockmount Replacement, Remove the shockmount: step 4, image 1 of 2 Wacker Compactor Plate VP1550AW 2014 Shockmount Replacement, Remove the shockmount: step 4, image 2 of 2
      • Pull the shockmount out of the guide handle.
      Ask FixBot
Arthur Shi
347,826 Reputation
927 Guides authored
iFixit Member of iFixit
Staff
123 Members
85,826 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 19
All Time: 944
