WRS315SDHW Icemaker Auger Assembly Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
13
Past 30 Days:
60
All Time:
459
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 30 - 45 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
Use this guide to replace the icemaker auger assembly in your Whirlpool WRS315SDHW Refrigerator.
The icemaker auger assembly directs water and ice to the dispenser. If your refrigerator isn't dispensing ice or water properly, your icemaker auger assembly might be broken. The assembly consists of an auger motor and solenoid—you can replace the parts individually if you know which specific part is broken.
Note: Some photos show the doors removed for clarity purposes. Removing them is not required and will not change the procedure.
    1. WRS315SDHW Icemaker Auger Assembly Replacement, Safety precautions: step 1, image 1 of 1
      • Before you begin your repair, perform the following:
      • Turn off your main water supply
      • Unplug your device
      Ask FixBot
    1. WRS315SDHW Icemaker Auger Assembly Replacement, Open the doors: step 2, image 1 of 3 WRS315SDHW Icemaker Auger Assembly Replacement, Open the doors: step 2, image 2 of 3 WRS315SDHW Icemaker Auger Assembly Replacement, Open the doors: step 2, image 3 of 3
      • Depending on your repair, open one or both doors.
      Ask FixBot
    1. WRS315SDHW Icemaker Auger Assembly Replacement, Remove the icemaker tray: step 3, image 1 of 2 WRS315SDHW Icemaker Auger Assembly Replacement, Remove the icemaker tray: step 3, image 2 of 2
      • Pull the icemaker tray completely out of its slot in the chassis.
      Ask FixBot
    2. WRS315SDHW Icemaker Auger Assembly Replacement, Unfasten the icemaker assembly: step 4, image 1 of 2 WRS315SDHW Icemaker Auger Assembly Replacement, Unfasten the icemaker assembly: step 4, image 2 of 2
      • Use a 1/4 inch socket wrench to remove the three screws securing the icemaker assembly (shown with the assembly removed):
      • Two 23.9 mm-long screws
      • One 16.7 mm-long screw
      Ask FixBot
    3. WRS315SDHW Icemaker Auger Assembly Replacement, Reposition the icemaker assembly: step 5, image 1 of 3 WRS315SDHW Icemaker Auger Assembly Replacement, Reposition the icemaker assembly: step 5, image 2 of 3 WRS315SDHW Icemaker Auger Assembly Replacement, Reposition the icemaker assembly: step 5, image 3 of 3
      • Pull the icemaker assembly toward the right edge of the refrigerator to release it from its slot in the chassis.
      • Let the icemaker assembly hang to access its connector.
      Ask FixBot
    4. WRS315SDHW Icemaker Auger Assembly Replacement, Disconnect the icemaker assembly: step 6, image 1 of 3 WRS315SDHW Icemaker Auger Assembly Replacement, Disconnect the icemaker assembly: step 6, image 2 of 3 WRS315SDHW Icemaker Auger Assembly Replacement, Disconnect the icemaker assembly: step 6, image 3 of 3
      • Disconnect the spade connector attached to the icemaker assembly.
      Ask FixBot
    5. WRS315SDHW Icemaker Auger Assembly Replacement, Remove the icemaker assembly: step 7, image 1 of 1
      • Remove the icemaker assembly.
      Ask FixBot
    1. WRS315SDHW Icemaker Auger Assembly Replacement, Unfasten the icemaker auger assembly: step 8, image 1 of 1
      • Use a 1/4 inch socket wrench to remove the four screws securing the icemaker auger assembly:
      • Two 24.1 mm-long screws
      • Two 16.5 mm-long screws
      Ask FixBot
    2. WRS315SDHW Icemaker Auger Assembly Replacement, Reposition the icemaker auger assembly: step 9, image 1 of 3 WRS315SDHW Icemaker Auger Assembly Replacement, Reposition the icemaker auger assembly: step 9, image 2 of 3 WRS315SDHW Icemaker Auger Assembly Replacement, Reposition the icemaker auger assembly: step 9, image 3 of 3
      • Pull the icemaker auger assembly off of its slot in the chassis.
      • Let the assembly hang to access its connector.
      Ask FixBot
    3. WRS315SDHW Icemaker Auger Assembly Replacement, Disconnect the icemaker auger assembly: step 10, image 1 of 3 WRS315SDHW Icemaker Auger Assembly Replacement, Disconnect the icemaker auger assembly: step 10, image 2 of 3 WRS315SDHW Icemaker Auger Assembly Replacement, Disconnect the icemaker auger assembly: step 10, image 3 of 3
      • Use a flathead screwdriver, or a similar tool, to compress the connector attached to the icemaker auger assembly.
      • Use your hands to disconnect the assembly connector.
      Ask FixBot
    4. WRS315SDHW Icemaker Auger Assembly Replacement, Remove the icemaker auger assembly: step 11, image 1 of 1
      • Remove the icemaker auger assembly.
      Ask FixBot
Repair didn’t go as planned? Ask our Answers community for help.
nicO
15,990 Reputation
88 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 13
Past 30 Days: 60
All Time: 459
