Up to 20% off select tools
WRS315SDHW Icemaker Assembly Replacement
Views: 1K
View statistics:
Past 24 Hours:
Past 7 Days:
17
Past 30 Days:
78
All Time:
1,026
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 - 20 minutes
Difficulty: Moderate
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Tools
Introduction
Go to step 1 ↓
Use this guide to replace the icemaker assembly in your Whirlpool WRS315SDHW Refrigerator.
The icemaker assembly is a combination of parts that creates ice. If your refrigerator isn't producing ice, or is producing too much ice, then your icemaker might be broken.
Note: Some photos show the doors removed for clarity purposes. Removing them is not required and will not change the procedure.
    1. WRS315SDHW Icemaker Assembly Replacement, Safety precautions: step 1, image 1 of 1
      • Before you begin your repair, perform the following:
      • Turn off your main water supply
      • Unplug your device
      Ask FixBot
    1. WRS315SDHW Icemaker Assembly Replacement, Open the doors: step 2, image 1 of 3 WRS315SDHW Icemaker Assembly Replacement, Open the doors: step 2, image 2 of 3 WRS315SDHW Icemaker Assembly Replacement, Open the doors: step 2, image 3 of 3
      • Depending on your repair, open one or both doors.
      Ask FixBot
    1. WRS315SDHW Icemaker Assembly Replacement, Remove the icemaker tray: step 3, image 1 of 2 WRS315SDHW Icemaker Assembly Replacement, Remove the icemaker tray: step 3, image 2 of 2
      • Pull the icemaker tray completely out of its slot in the chassis.
      Ask FixBot
    2. WRS315SDHW Icemaker Assembly Replacement, Unfasten the icemaker assembly: step 4, image 1 of 2 WRS315SDHW Icemaker Assembly Replacement, Unfasten the icemaker assembly: step 4, image 2 of 2
      • Use a 1/4 inch socket wrench to remove the three screws securing the icemaker assembly (shown with the assembly removed):
      • Two 23.9 mm-long screws
      • One 16.7 mm-long screw
      Ask FixBot
    3. WRS315SDHW Icemaker Assembly Replacement, Reposition the icemaker assembly: step 5, image 1 of 3 WRS315SDHW Icemaker Assembly Replacement, Reposition the icemaker assembly: step 5, image 2 of 3 WRS315SDHW Icemaker Assembly Replacement, Reposition the icemaker assembly: step 5, image 3 of 3
      • Pull the icemaker assembly toward the right edge of the refrigerator to release it from its slot in the chassis.
      • Let the icemaker assembly hang to access its connector.
      Ask FixBot
    4. WRS315SDHW Icemaker Assembly Replacement, Disconnect the icemaker assembly: step 6, image 1 of 3 WRS315SDHW Icemaker Assembly Replacement, Disconnect the icemaker assembly: step 6, image 2 of 3 WRS315SDHW Icemaker Assembly Replacement, Disconnect the icemaker assembly: step 6, image 3 of 3
      • Disconnect the spade connector attached to the icemaker assembly.
      Ask FixBot
    5. WRS315SDHW Icemaker Assembly Replacement, Remove the icemaker assembly: step 7, image 1 of 1
      • Remove the icemaker assembly.
      Ask FixBot
Repair didn’t go as planned? Ask our Answers community for help.
Author
with
nicO
15,990 Reputation
88 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 17
Past 30 Days: 78
All Time: 1,026
