WRS315SDHW Freezer Door Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
20
Past 30 Days:
74
All Time:
450
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 30 - 45 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
Use this guide to remove or replace the freezer door in your Whirlpool WRS315SDHW Refrigerator.
This guide replaces the entire freezer door as a unit.
    1. WRS315SDHW Freezer Door Replacement, Safety precautions: step 1, image 1 of 1
      • Before you begin your repair, perform the following:
      • Turn off your main water supply
      • Unplug your device
      Ask FixBot
    1. WRS315SDHW Freezer Door Replacement, Open the doors: step 2, image 1 of 3 WRS315SDHW Freezer Door Replacement, Open the doors: step 2, image 2 of 3 WRS315SDHW Freezer Door Replacement, Open the doors: step 2, image 3 of 3
      • Depending on your repair, open one or both doors.
      Ask FixBot
    1. WRS315SDHW Freezer Door Replacement, Unfasten the front panel: step 3, image 1 of 3 WRS315SDHW Freezer Door Replacement, Unfasten the front panel: step 3, image 2 of 3 WRS315SDHW Freezer Door Replacement, Unfasten the front panel: step 3, image 3 of 3
      • Use a Phillips driver to remove the two 15.2 mm-long screws securing the front panel.
      Ask FixBot
    2. WRS315SDHW Freezer Door Replacement, Remove the front panel: step 4, image 1 of 3 WRS315SDHW Freezer Door Replacement, Remove the front panel: step 4, image 2 of 3 WRS315SDHW Freezer Door Replacement, Remove the front panel: step 4, image 3 of 3
      • Pull the front panel straight off the chassis and remove it.
      • You may have to slightly open the water filter door to remove the front panel completely.
      Ask FixBot
    1. WRS315SDHW Freezer Door Replacement, Unfasten the door connections: step 5, image 1 of 2 WRS315SDHW Freezer Door Replacement, Unfasten the door connections: step 5, image 2 of 2
      • Use a 1/4 inch socket wrench to remove the 16.7 mm-long screw securing the freezer door wiring harness.
      • Use a 1/4 inch socket wrench to remove the 16.2 mm-long screw securing the freezer door water hose.
      Ask FixBot
    2. WRS315SDHW Freezer Door Replacement, Reposition the wiring harness: step 6, image 1 of 2 WRS315SDHW Freezer Door Replacement, Reposition the wiring harness: step 6, image 2 of 2
      • Pull the wiring harness out of its slot in the chassis to access its connectors.
      Ask FixBot
    3. WRS315SDHW Freezer Door Replacement, Disconnect the wiring harness: step 7, image 1 of 3 WRS315SDHW Freezer Door Replacement, Disconnect the wiring harness: step 7, image 2 of 3 WRS315SDHW Freezer Door Replacement, Disconnect the wiring harness: step 7, image 3 of 3
      • Disconnect the two connectors attached to the door wiring harness.
      Ask FixBot
    4. WRS315SDHW Freezer Door Replacement: step 8, image 1 of 1
      • Place a clean cloth under the water hose before continuing.
      Ask FixBot
    5. WRS315SDHW Freezer Door Replacement: step 9, image 1 of 2 WRS315SDHW Freezer Door Replacement: step 9, image 2 of 2
      • Pull the plastic clip off the freezer door water hose.
      Ask FixBot
    6. WRS315SDHW Freezer Door Replacement, Disconnect the water hose: step 10, image 1 of 3 WRS315SDHW Freezer Door Replacement, Disconnect the water hose: step 10, image 2 of 3 WRS315SDHW Freezer Door Replacement, Disconnect the water hose: step 10, image 3 of 3
      • Use one hand to compress the blue plastic ring into the green section of the hose.
      • Use the other hand to pull the white water tube out of its slot.
      Ask FixBot
    7. WRS315SDHW Freezer Door Replacement, Unfasten the freezer door: step 11, image 1 of 2 WRS315SDHW Freezer Door Replacement, Unfasten the freezer door: step 11, image 2 of 2
      • Hold the door while performing the next two steps to avoid the door from accidentally falling.
      • Use a 3/16 inch Allen wrench to remove the two 19.3 mm-long screws securing the freezer door.
      • The Torx screws are for alignment and don't need to be removed.
      Ask FixBot
    8. WRS315SDHW Freezer Door Replacement, Remove the door hinge: step 12, image 1 of 3 WRS315SDHW Freezer Door Replacement, Remove the door hinge: step 12, image 2 of 3 WRS315SDHW Freezer Door Replacement, Remove the door hinge: step 12, image 3 of 3
      • Pull the door hinge straight up to separate its alignment pins from the chassis.
      • Remove the door hinge.
      Ask FixBot
    9. WRS315SDHW Freezer Door Replacement, Reposition the cables: step 13, image 1 of 3 WRS315SDHW Freezer Door Replacement, Reposition the cables: step 13, image 2 of 3 WRS315SDHW Freezer Door Replacement, Reposition the cables: step 13, image 3 of 3
      • Pull the freezer door straight up to disconnect it from the chassis.
      • Thread the cables through their slot in the chassis.
      • You may need to thread them individually.
      Ask FixBot
    10. WRS315SDHW Freezer Door Replacement, Remove the door: step 14, image 1 of 2 WRS315SDHW Freezer Door Replacement, Remove the door: step 14, image 2 of 2
      • You're now left with the freezer door.
      Ask FixBot
Repair didn’t go as planned? Ask our Answers community for help.
nicO
15,990 Reputation
88 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 20
Past 30 Days: 74
All Time: 450
