WRS315SDHW Defrost Thermistor Replacement
    1. WRS315SDHW Defrost Thermistor Replacement, Safety precautions: step 1, image 1 of 1
      • Before you begin your repair, perform the following:
      • Turn off your main water supply
      • Unplug your device
      Ask FixBot
    1. WRS315SDHW Defrost Thermistor Replacement, Open the doors: step 2, image 1 of 3 WRS315SDHW Defrost Thermistor Replacement, Open the doors: step 2, image 2 of 3 WRS315SDHW Defrost Thermistor Replacement, Open the doors: step 2, image 3 of 3
      • Depending on your repair, open one or both doors.
      Ask FixBot
    1. WRS315SDHW Defrost Thermistor Replacement, Remove the drawers: step 3, image 1 of 2 WRS315SDHW Defrost Thermistor Replacement, Remove the drawers: step 3, image 2 of 2
      • Remove the drawers and shelves from the freezer section.
      Ask FixBot
    2. WRS315SDHW Defrost Thermistor Replacement: step 4, image 1 of 2 WRS315SDHW Defrost Thermistor Replacement: step 4, image 2 of 2
      • Remove the screw(s) securing the evaporator cover.
      Ask FixBot
    3. WRS315SDHW Defrost Thermistor Replacement, Unclip the evaporator cover: step 5, image 1 of 3 WRS315SDHW Defrost Thermistor Replacement, Unclip the evaporator cover: step 5, image 2 of 3 WRS315SDHW Defrost Thermistor Replacement, Unclip the evaporator cover: step 5, image 3 of 3
      • Lift the bottom of the evaporator cover up and over its lip in the chassis.
      • Pull the cover toward yourself to release its top clips.
      Ask FixBot
    4. WRS315SDHW Defrost Thermistor Replacement, Remove the evaporator cover: step 6, image 1 of 3 WRS315SDHW Defrost Thermistor Replacement, Remove the evaporator cover: step 6, image 2 of 3 WRS315SDHW Defrost Thermistor Replacement, Remove the evaporator cover: step 6, image 3 of 3
      • Continue pulling the evaporator cover towards yourself to unclip its metal prongs from the chassis.
      • Remove the evaporator cover.
      Ask FixBot
    1. WRS315SDHW Defrost Thermistor Replacement, Unclip the thermistor: step 7, image 1 of 3 WRS315SDHW Defrost Thermistor Replacement, Unclip the thermistor: step 7, image 2 of 3 WRS315SDHW Defrost Thermistor Replacement, Unclip the thermistor: step 7, image 3 of 3
      • Use a spudger to push the tip of the thermistor through its slot in the wire harness.
      Ask FixBot
    2. WRS315SDHW Defrost Thermistor Replacement, Disconnect the thermistor: step 8, image 1 of 2 WRS315SDHW Defrost Thermistor Replacement, Disconnect the thermistor: step 8, image 2 of 2
      • Disconnect the thermistor from the wiring harness.
      Ask FixBot
    3. WRS315SDHW Defrost Thermistor Replacement, Remove the thermistor: step 9, image 1 of 1
      • Remove the thermistor.
      Ask FixBot
Repair didn’t go as planned? Ask our Answers community for help.
nicO
15,990 Reputation
89 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 43
All Time: 704
