WRS315SDHW Control Board Replacement
Views: 1.1K
View statistics:
Past 24 Hours:
3
Past 7 Days:
18
Past 30 Days:
75
All Time:
1,083
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 - 30 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
Use this guide to replace the control board in your Whirlpool WRS315SDHW Refrigerator.
The control board processes the inputs for the dispenser assembly and other related assemblies. If your refrigerator is not dispensing properly, or if the dispenser buttons on your refrigerator aren't working, then your control board might be broken.
Note: Some photos show the doors removed for clarity purposes. Removing them is not required and will not change the procedure.
    1. WRS315SDHW Control Board Replacement, Safety precautions: step 1, image 1 of 1
      • Before you begin your repair, perform the following:
      • Turn off your main water supply
      • Unplug your device
      Ask FixBot
    1. WRS315SDHW Control Board Replacement, Unfasten the dispenser panels: step 2, image 1 of 2 WRS315SDHW Control Board Replacement, Unfasten the dispenser panels: step 2, image 2 of 2
      • The dispenser panel screws are located under the dispenser as if you're looking up into the dispenser tube (where the ice cubes and water come out).
      • Use a 1/4 inch socket wrench to remove the two 15.6 mm-long screws securing the two dispenser panels.
      Ask FixBot
    2. WRS315SDHW Control Board Replacement, Remove the dispenser panels: step 3, image 1 of 3 WRS315SDHW Control Board Replacement, Remove the dispenser panels: step 3, image 2 of 3 WRS315SDHW Control Board Replacement, Remove the dispenser panels: step 3, image 3 of 3
      • Pull the dispenser panels straight down to separate them from the chassis.
      • Remove the dispenser panels.
      Ask FixBot
    3. WRS315SDHW Control Board Replacement, Unfasten the control board: step 4, image 1 of 1
      • Use a 1/4 inch socket wrench to remove the two 15.6 mm-long screws securing the control board.
      Ask FixBot
    4. WRS315SDHW Control Board Replacement: step 5, image 1 of 3 WRS315SDHW Control Board Replacement: step 5, image 2 of 3 WRS315SDHW Control Board Replacement: step 5, image 3 of 3
      • Tilt the bottom of the control board away from the chassis to release its clips.
      • Pull straight down to separate the control board enough to access its connectors.
      Ask FixBot
    5. WRS315SDHW Control Board Replacement, Disconnect the control board: step 6, image 1 of 3 WRS315SDHW Control Board Replacement, Disconnect the control board: step 6, image 2 of 3 WRS315SDHW Control Board Replacement, Disconnect the control board: step 6, image 3 of 3
      • Disconnect the large connector attached to the right edge of the control board.
      Ask FixBot
    6. WRS315SDHW Control Board Replacement: step 7, image 1 of 2 WRS315SDHW Control Board Replacement: step 7, image 2 of 2
      • Disconnect the small connector attached to the left edge of the control board.
      Ask FixBot
    7. WRS315SDHW Control Board Replacement, Remove the control board: step 8, image 1 of 1
      • Remove the control board.
      Ask FixBot
Repair didn’t go as planned? Ask our Answers community for help.
nicO
15,990 Reputation
88 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 18
Past 30 Days: 75
All Time: 1,083
