WRS315SDHW Condenser Fan Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
19
Past 30 Days:
67
All Time:
492
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 - 30 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
Use this guide to replace the condenser fan in your Whirlpool WRS315SDHW Refrigerator.
The condenser fan draws air over the compressor and through the condenser coils. If your refrigerator won't cool properly, then the condenser fan might be broken.
Note: Some photos show the doors removed for clarity purposes. Removing them is not required and will not change the procedure.
    1. WRS315SDHW Condenser Fan Replacement, Safety precautions: step 1, image 1 of 1
      • Before you begin your repair, perform the following:
      • Turn off your main water supply
      • Unplug your device
      Ask FixBot
    1. WRS315SDHW Condenser Fan Replacement, Unfasten the rear panel: step 2, image 1 of 3 WRS315SDHW Condenser Fan Replacement, Unfasten the rear panel: step 2, image 2 of 3 WRS315SDHW Condenser Fan Replacement, Unfasten the rear panel: step 2, image 3 of 3
      • Use a 1/4 inch socket wrench, or a flathead screwdriver, to remove the seven 16.2 mm-long screws securing the rear panel.
      • Use a 1/4 inch socket wrench to loosen the screw securing the water hose enough for the rear panel to freely move.
      Ask FixBot
    2. WRS315SDHW Condenser Fan Replacement, Remove the rear panel: step 3, image 1 of 3 WRS315SDHW Condenser Fan Replacement, Remove the rear panel: step 3, image 2 of 3 WRS315SDHW Condenser Fan Replacement, Remove the rear panel: step 3, image 3 of 3
      • Pull the rear panel off the chassis to remove it.
      Ask FixBot
    1. WRS315SDHW Condenser Fan Replacement, Disconnect the condenser fan: step 4, image 1 of 2 WRS315SDHW Condenser Fan Replacement, Disconnect the condenser fan: step 4, image 2 of 2
      • Press the tab on the condenser fan cable connector to unclip it.
      • Pull the connector straight out of its slot to remove it.
      Ask FixBot
    2. WRS315SDHW Condenser Fan Replacement, Remove the condenser fan: step 5, image 1 of 3 WRS315SDHW Condenser Fan Replacement, Remove the condenser fan: step 5, image 2 of 3 WRS315SDHW Condenser Fan Replacement, Remove the condenser fan: step 5, image 3 of 3
      • Put on gloves before continuing, as the sheet metal and the fan itself are sharp.
      • Pull the condenser fan straight off its peg to remove it.
      Ask FixBot
    3. WRS315SDHW Condenser Fan Replacement, Unfasten the condenser fan motor: step 6, image 1 of 1
      • Use a 1/4 inch socket wrench to remove the four 16.5 mm-long screws securing the condenser fan motor to the chassis.
      Ask FixBot
    4. WRS315SDHW Condenser Fan Replacement, Remove the motor: step 7, image 1 of 3 WRS315SDHW Condenser Fan Replacement, Remove the motor: step 7, image 2 of 3 WRS315SDHW Condenser Fan Replacement, Remove the motor: step 7, image 3 of 3
      • Rotate the motor housing through its slot in the chassis.
      • Remove the motor.
      Ask FixBot
Repair didn’t go as planned? Ask our Answers community for help.
nicO
15,990 Reputation
88 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 19
Past 30 Days: 67
All Time: 492
