Introduction
If your W-King X10 has been functioning normally, but you are unable to charge the battery, you may have a problem with your charging port. When plugged in, the LED indicators at the top of the X10 should light up and blink white to indicate a charging battery and the level that the battery is charged.
After following our troubleshooting guide for potential quick-fixes, consider replacing the charging port itself by following this replacement guide.
Before you begin this repair, power off your speaker and disconnect it from the charging cable.
The prerequisite guide to remove the speakers requires soldering. For detailed instructions, refer to the How to Solder and Desolder Connections guide.
Lay the X10 on its back so that the bottom is facing you.
Using the metal spudger, separate the two connection points located on the left and right sides of the mesh panel as shown.
Separate the connection point in the center of the bottom section of the device.
As before, all connection points should audibly 'pop' when disconnected, and the mesh panel will visibly separate from the body of the X10.
Use a soldering iron to disconnect the three wires connecting the speaker to the motherboard.
Unscrew the top arm of the X10.
There are four 7.5mm Phillips #0 screws at the center of the top arm.
There are two 7.5mm Phillips #0 screws at the base of each side of the arm.
Use a Phillips #0 screwdriver to remove the four 7.5 mm screws connecting the casing motherboard to the case.
Use a soldering iron to desolder the four connection points attaching the charging port to the motherboard.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
