Vtech Kidizoom Smart Watch DX Battery Replacement
    1. Vtech Kidizoom Smart Watch DX Battery Replacement, Master Switch: step 1, image 1 of 1
      • Make sure the master switch is "OFF" before disassembly, to avoid an electric shock.
      • Flip the watch over with the back facing up.
      Ask FixBot
    2. Vtech Kidizoom Smart Watch DX Battery Replacement: step 2, image 1 of 1
      • Remove the four 6.0 mm screws on the back plate with the Phillips #00 screwdriver.
      Ask FixBot
    3. Vtech Kidizoom Smart Watch DX Battery Replacement: step 3, image 1 of 1
      • Gently pull the back plate from the watch casing.
      Ask FixBot
    4. Vtech Kidizoom Smart Watch DX Battery Replacement: step 4, image 1 of 2 Vtech Kidizoom Smart Watch DX Battery Replacement: step 4, image 2 of 2
      • Lift the master switch from the circuit board.
      Ask FixBot
    1. Vtech Kidizoom Smart Watch DX Battery Replacement, Circuit Board: step 5, image 1 of 2 Vtech Kidizoom Smart Watch DX Battery Replacement, Circuit Board: step 5, image 2 of 2
      • The speaker wires are fragile. They may break if excessive force is used to remove the circuit board.
      • Removal of the circuit board requires soldering.
      • Gently push on the display from the front, near the camera. The circuit board and display will pop out through the back.
      Ask FixBot
    2. Vtech Kidizoom Smart Watch DX Battery Replacement: step 6, image 1 of 1
      • Lift the circuit board carefully from the casing, without breaking or detaching the speaker wires at the bottom of the circuit board.
      Ask FixBot
    3. Vtech Kidizoom Smart Watch DX Battery Replacement: step 7, image 1 of 1
      • Note which wire is connected to which lead before continuing. There are no markers on the circuit board to indicate where each wire belongs.
      • De-solder the black speaker wire from the circuit board.
      Ask FixBot
    4. Vtech Kidizoom Smart Watch DX Battery Replacement: step 8, image 1 of 1
      • De-solder the red speaker wire, as in the previous step.
      Ask FixBot
    5. Vtech Kidizoom Smart Watch DX Battery Replacement: step 9, image 1 of 1
      • Wait for the solder to cool down and solidify, then remove the circuit board from the casing.
      Ask FixBot
    1. Vtech Kidizoom Smart Watch DX Battery Replacement, Battery: step 10, image 1 of 2 Vtech Kidizoom Smart Watch DX Battery Replacement, Battery: step 10, image 2 of 2
      • Using the plastic opening tool, gently pry the edges of the battery away from from the circuit board.
      • There is a thin layer of adhesive holding the battery to the circuit board. This will remain sticky after prying.
      Ask FixBot
    2. Vtech Kidizoom Smart Watch DX Battery Replacement: step 11, image 1 of 1
      • De-solder the red battery wire from the circuit board.
      Ask FixBot
    3. Vtech Kidizoom Smart Watch DX Battery Replacement: step 12, image 1 of 1
      • Repeat the de-soldering for the black (ground) wire.
      Ask FixBot
    4. Vtech Kidizoom Smart Watch DX Battery Replacement: step 13, image 1 of 1
      • Pull the battery free, and wait for the solder to cool before handling further.
      Ask FixBot
6 other people completed this guide.
Navin Ramkishun
283 Reputation
1 Guide authored
USF Tampa, Team 10-6, Remmell Spring 2016 Member of USF Tampa, Team 10-6, Remmell Spring 2016
USFT-REMMELL-S16S10G6
4 Members
72 Guides authored
1 Guide Comment
Where did you bought the battery?
funkysoulbrother - Reply Share
Past 24 Hours: 3
Past 7 Days: 30
Past 30 Days: 84
All Time: 10,449
