Vtech Kidibeats Drum Set Volume Switch Replacement
  1. Vtech Kidibeats Drum Set Volume Switch Replacement, Back Panel: step 1, image 1 of 1
    • Locate the battery panel that is centered between the three leg supports at the bottom of the drum set.
    Ask FixBot
  2. Vtech Kidibeats Drum Set Volume Switch Replacement: step 2, image 1 of 1
    • To remove the battery panel, loosen the 10 mm panel screw using a flathead 4.0 screwdriver.
    • You can also use a small coin to loosen the screw.
    Ask FixBot
  3. Vtech Kidibeats Drum Set Volume Switch Replacement: step 3, image 1 of 1
    • Using your fingers, pry open and remove the back battery panel.
    Ask FixBot
  4. Vtech Kidibeats Drum Set Volume Switch Replacement: step 4, image 1 of 1
    • Use your fingers to remove each battery from its housing.
    Ask FixBot
  5. Vtech Kidibeats Drum Set Volume Switch Replacement: step 5, image 1 of 1
    • Using a Phillips #2 screwdriver, loosen and remove the six 14 mm screws.
    Ask FixBot
  6. Vtech Kidibeats Drum Set Volume Switch Replacement: step 6, image 1 of 2 Vtech Kidibeats Drum Set Volume Switch Replacement: step 6, image 2 of 2
    • With your hands, separate the bottom panel from the drum set.
    • When removing the bottom panel, be careful not to pull too hard in order to prevent damaging the connections from the motherboard to the speaker and power source.
    Ask FixBot
  7. Vtech Kidibeats Drum Set Volume Switch Replacement, Volume Switch: step 7, image 1 of 1
    • Loosen and remove the two 8 mm screws using a Phillips #00 screwdriver.
    Ask FixBot
  8. Vtech Kidibeats Drum Set Volume Switch Replacement: step 8, image 1 of 1
    • Use your fingers to gently remove the volume switch from its setting.
    Ask FixBot
  9. Vtech Kidibeats Drum Set Volume Switch Replacement: step 9, image 1 of 1
    Ask FixBot
Aaron Klementowski
847 Reputation
6 Guides authored
USF Tampa, Team 2-8, Cagle Spring 2016 Member of USF Tampa, Team 2-8, Cagle Spring 2016
USFT-CAGLE-S16S2G8
2 Members
12 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 27
All Time: 1,137
