Up to 20% off select tools
Vtech Innotab 3 Microphone Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
14
Past 30 Days:
84
All Time:
931
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Missing Details
Some of this guide's details are missing. Help users by adding tools, difficulty, or time.
Tools
Introduction
Go to step 1 ↓
In order to replace the microphone grab yourself a PH00 screwdriver, a metal spudger, and a soldering kit.
  • Before you begin disassembling the Vtech InnoTab 3, turn on your soldering iron. If working with others let them know that the soldering iron is on and to use caution.
    1. Vtech Innotab 3 Microphone Replacement, Rear Panel: step 1, image 1 of 3 Vtech Innotab 3 Microphone Replacement, Rear Panel: step 1, image 2 of 3 Vtech Innotab 3 Microphone Replacement, Rear Panel: step 1, image 3 of 3
      • Slide the battery compartment door lock down.
      • While still holding the battery compartment lock down, slide the two battery doors outwards on either side of the device.
      • Carefully remove the batteries from the battery compartment.
      • The standard option for the InnoTab 3 is four AA batteries. Vtech also offers a rechargeable battery online, but both battery options are removed from the device the same way.
      Ask FixBot
    2. Vtech Innotab 3 Microphone Replacement: step 2, image 1 of 1
      • Remove the six 7.6mm screws found in the battery compartment using a PH00 screwdriver.
      Ask FixBot
    3. Vtech Innotab 3 Microphone Replacement: step 3, image 1 of 3 Vtech Innotab 3 Microphone Replacement: step 3, image 2 of 3 Vtech Innotab 3 Microphone Replacement: step 3, image 3 of 3
      • There are three hidden screws on the back of the device, two at the top and one near the bottom.
      • Using a nylon or metal spudger, remove the three caps that hide the screws.
      • Remove the 5mm screw near the bottom and the two 7.6mm at the top using a PH00 screwdriver.
      Ask FixBot
    4. Vtech Innotab 3 Microphone Replacement: step 4, image 1 of 1
      • Carefully separate the back panel from the front panel revealing the motherboard connected to the front panel.
      Ask FixBot
    1. Vtech Innotab 3 Microphone Replacement, Microphone: step 5, image 1 of 3 Vtech Innotab 3 Microphone Replacement, Microphone: step 5, image 2 of 3 Vtech Innotab 3 Microphone Replacement, Microphone: step 5, image 3 of 3
      • Remove the four 7.6 mm screws using a PH00 screwdriver.
      • Lift up the circuit board from the device.
      Ask FixBot
    2. Vtech Innotab 3 Microphone Replacement: step 6, image 1 of 3 Vtech Innotab 3 Microphone Replacement: step 6, image 2 of 3 Vtech Innotab 3 Microphone Replacement: step 6, image 3 of 3
      Tool used on this step:
      Buy
      • To replace the microphone, desolder the two connections that connect the speaker to the device.
      • Use tweezers to keep the microphone steady as you desolder the connections.
      • This is a tricky step. Refer to this guide to learn how to solder: How To Solder and Desolder Connections
      Ask FixBot
Author
with
Zach Diviney
419 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 14
Past 30 Days: 84
All Time: 931
