Introduction
In order to replace the headphone port grab yourself a PH00 screwdriver, a metal spudger, and a soldering kit.
- Before you begin disassembling the Vtech InnoTab 3, turn on your soldering iron. If working with others let them know that the soldering iron is on and to use caution.
Slide the battery compartment door lock down.
While still holding the battery compartment lock down, slide the two battery doors outwards on either side of the device.
Carefully remove the batteries from the battery compartment.
Tool used on this step:Tweezers$4.99
On the front panel of the device, the headphone poet is located at the bottom right corner of the device, opposte of the speaker.
Using tweezers, lift up to remove the headphone port from its holding.
