Student In Progress
This guide is being worked on by hardworking students.
Tools
Introduction
Go to step 1 ↓This guide will walk you through replacing the USB port on your childs Vtech InnoTab 3S.
While holding the battery compartment locks down, slide the two battery doors outwards from the sides of the device.
Remove the batteries from the device.
Remove the six screws that secure the motherboard to the front panel of the device using a Phillips #1 screwdriver.
Next, remove the two 5 mm screws that secure the charger port (upper right and bottom center).
Then, remove the six 3 mm screws securing the battery clip.
Facing the underside of the USB port, solder the metal prongs securing the USB port to the device.
2 other people completed this guide.
