Up to 20% off select tools
Vtech InnoTab 3S Screen Replacement
Views: 3K
View statistics:
Past 24 Hours:
4
Past 7 Days:
17
Past 30 Days:
97
All Time:
2,975
Comments: 4
4 guide comments.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 - 25 minutes
Difficulty: Moderate
Student In Progress
This guide is being worked on by hardworking students.
Tools
Introduction
Go to step 1 ↓
Is your InnoTab 3S screen cracked? This guide will walk you through replacing the screen of the Vtech InnoTab 3S.
    1. Vtech InnoTab 3S Screen Replacement, Rear Panel: step 1, image 1 of 3 Vtech InnoTab 3S Screen Replacement, Rear Panel: step 1, image 2 of 3 Vtech InnoTab 3S Screen Replacement, Rear Panel: step 1, image 3 of 3
      • While holding the battery compartment locks down, slide the two battery doors outwards from the sides of the device.
      • Remove the batteries from the device.
      Ask FixBot
    2. Vtech InnoTab 3S Screen Replacement: step 2, image 1 of 3 Vtech InnoTab 3S Screen Replacement: step 2, image 2 of 3 Vtech InnoTab 3S Screen Replacement: step 2, image 3 of 3
      • Using a nylon spudger, remove the five caps that hide the screws.
      • Potential device damage: Be careful not to scrape the plastic from the device using the spudger.
      • For easier cap removal, hold the spudger vertically to the board and push, towards the bottom of the device.
      • Remove the five 5 mm screws from the rear panel of the device, using a Phillips #1 screwdriver.
      Ask FixBot
    3. Vtech InnoTab 3S Screen Replacement: step 3, image 1 of 2 Vtech InnoTab 3S Screen Replacement: step 3, image 2 of 2
      • Remove the six 7 mm screws from the interior battery compartment using a Phillips #1 screwdriver.
      Ask FixBot
    4. Vtech InnoTab 3S Screen Replacement: step 4, image 1 of 1
      • Carefully remove the rear panel from the device.
      • Once the rear panel is removed, the motherboard and other components in the Vtech InnoTab 3S are visible and accessible.
      Ask FixBot
    1. Vtech InnoTab 3S Screen Replacement, Motherboard: step 5, image 1 of 2 Vtech InnoTab 3S Screen Replacement, Motherboard: step 5, image 2 of 2
      • Remove the six screws that secure the motherboard to the front panel of the device using a Phillips #1 screwdriver.
      • Next, remove the two 5 mm screws that secure the charger port (upper right and bottom center).
      • Then, remove the six 3 mm screws securing the battery clip.
      Ask FixBot
    2. Vtech InnoTab 3S Screen Replacement: step 6, image 1 of 1
      Tool used on this step:
      Buy
      • Using the tweezers, remove the battery clips from each corner (four total) of the Vtech InnoTab 3s.
      • With the tweezers, detached the charging port, headphone port, and the light switch button from the front panel of the device.
      • Potential device damage: To prevent damage to the motherboard and other surrounding device components, avoid forceful movements.
      Ask FixBot
    1. Vtech InnoTab 3S Screen Replacement, Screen: step 7, image 1 of 3 Vtech InnoTab 3S Screen Replacement, Screen: step 7, image 2 of 3 Vtech InnoTab 3S Screen Replacement, Screen: step 7, image 3 of 3
      • Open the clip holding the screen plug with the yellow film.
      • The clip securing the screen is located at the top of the motherboard.
      • Remove all seven of the 5mm screws on the motherboard to separate the motherboard from the screen.
      Ask FixBot
    2. Vtech InnoTab 3S Screen Replacement: step 8, image 1 of 2 Vtech InnoTab 3S Screen Replacement: step 8, image 2 of 2
      • Avoid forceful movements when separating the screen from the motherboard.
      • Carefully separate the motherboard from the device screen. Replace the damaged screen with an operational one.
      Ask FixBot
Author
with
Karina Garcia
878 Reputation
6 Guides authored
USF Tampa, Team 8-2, Eyestone Fall 2015 Member of USF Tampa, Team 8-2, Eyestone Fall 2015
USFT-EYESTONE-F15S8G2
4 Members
108 Guides authored
4 Guide Comments
What is the part number for the screen. Where can I buy one. Thank you.
david goodwin - Reply Share
what is the size of the screen
Adrienne Dooms - Reply Share
My grandson dropped his innotab 3 and now the screen is all scrambled. Can this be fixed? It did not crack the screen.
charma1963 - Reply Share
Where can I buy the replacement screen for the Vtech innotab 3S
Michael Kurrus - Reply Share
Past 24 Hours: 4
Past 7 Days: 17
Past 30 Days: 97
All Time: 2,975
