Up to 20% off select tools
Vtech InnoTab 3S Rear Panel Replacement
Views: 1.3K
View statistics:
Past 24 Hours:
0
Past 7 Days:
4
Past 30 Days:
71
All Time:
1,277
Comments: 1
1 guide comment.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 8 - 20 minutes
Difficulty: Moderate
Student In Progress
This guide is being worked on by hardworking students.
Tools
Introduction
Go to step 1 ↓
In order to repair the Vtech InnoTab 3s, it's necessary to know how to properly take apart the rear panel of the device.
The standard battery options for the InnoTab 3S is four AA batteries. Vtech also offers a rechargeable battery online. Both battery options are removed from the device in the same way.
    1. Vtech InnoTab 3S Rear Panel Replacement, Rear Panel: step 1, image 1 of 3 Vtech InnoTab 3S Rear Panel Replacement, Rear Panel: step 1, image 2 of 3 Vtech InnoTab 3S Rear Panel Replacement, Rear Panel: step 1, image 3 of 3
      • While holding the battery compartment locks down, slide the two battery doors outwards from the sides of the device.
      • Remove the batteries from the device.
      Ask FixBot
    2. Vtech InnoTab 3S Rear Panel Replacement: step 2, image 1 of 3 Vtech InnoTab 3S Rear Panel Replacement: step 2, image 2 of 3 Vtech InnoTab 3S Rear Panel Replacement: step 2, image 3 of 3
      • Using a nylon spudger, remove the five caps that hide the screws.
      • Potential device damage: Be careful not to scrape the plastic from the device using the spudger.
      • For easier cap removal, hold the spudger vertically to the board and push, towards the bottom of the device.
      • Remove the five 5 mm screws from the rear panel of the device, using a Phillips #1 screwdriver.
      Ask FixBot
    3. Vtech InnoTab 3S Rear Panel Replacement: step 3, image 1 of 2 Vtech InnoTab 3S Rear Panel Replacement: step 3, image 2 of 2
      • Remove the six 7 mm screws from the interior battery compartment using a Phillips #1 screwdriver.
      Ask FixBot
    4. Vtech InnoTab 3S Rear Panel Replacement: step 4, image 1 of 1
      • Carefully remove the rear panel from the device.
      • Once the rear panel is removed, the motherboard and other components in the Vtech InnoTab 3S are visible and accessible.
      Ask FixBot
Author
with
Karina Garcia
878 Reputation
6 Guides authored
USF Tampa, Team 8-2, Eyestone Fall 2015 Member of USF Tampa, Team 8-2, Eyestone Fall 2015
USFT-EYESTONE-F15S8G2
4 Members
108 Guides authored
1 Guide Comment
too dumb i tryed 7 times it didnt work i reat this 1000000-/10
Kyron Ostrander - Reply Share
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 71
All Time: 1,277
