Student In Progress
This guide is being worked on by hardworking students.
Markup Mishap
This guide needs better markups. Help out by correcting or making some markup annotations.
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
Introduction
Go to step 1 ↓Your Vtech Inno Tab 3S is an educational Wi-Fi learning tablet for kids 3-9 years of age. The built-in microphone records audio and enables voice-and sound-activated gameplay across learning games and apps. If the microphone is not working, you can perform a few quick troubleshooting steps, shown in the VTech InnoTab 3S User Manual.
If the microphone is still not working after troubleshooting, the iFixit VTech InnoTab 3S Repair Page will allow you to see the exact screw and component layout before you begin. In addition, this guide will walk you through removing and replacing the tablet microphone.
Before starting, always power off and unplug your device to avoid any electrical hazards.
While holding the battery compartment locks down, slide the two battery doors outwards from the sides of the device.
Remove the batteries from the device.
Remove the six screws that secure the motherboard to the front panel of the device using a Phillips #1 screwdriver.
Next, remove the two 5 mm screws that secure the charger port (upper right and bottom center).
Then, remove the six 3 mm screws securing the battery clip.
Tool used on this step:Tweezers$4.99
Solder the prongs to unsecure the microphone from the device.
Using the tweezers carefully remove the microphone from the device.
