Up to 20% off select tools
Vtech InnoTab 3S Camera Replacement
Views: 2.7K
View statistics:
Past 24 Hours:
3
Past 7 Days:
13
Past 30 Days:
90
All Time:
2,658
Comments: 5
1 comment on steps, 4 guide comments.
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 - 25 minutes
Difficulty: Moderate
Student In Progress
This guide is being worked on by hardworking students.
Tools
Introduction
Go to step 1 ↓
Is the camera not working properly on your child's tablet? This guide will walk you through replacing the camera on the Vtech InnoTab 3S.
    1. Vtech InnoTab 3S Camera Replacement, Rear Panel: step 1, image 1 of 3 Vtech InnoTab 3S Camera Replacement, Rear Panel: step 1, image 2 of 3 Vtech InnoTab 3S Camera Replacement, Rear Panel: step 1, image 3 of 3
      • While holding the battery compartment locks down, slide the two battery doors outwards from the sides of the device.
      • Remove the batteries from the device.
      Ask FixBot
    2. Vtech InnoTab 3S Camera Replacement: step 2, image 1 of 3 Vtech InnoTab 3S Camera Replacement: step 2, image 2 of 3 Vtech InnoTab 3S Camera Replacement: step 2, image 3 of 3
      • Using a nylon spudger, remove the five caps that hide the screws.
      • Potential device damage: Be careful not to scrape the plastic from the device using the spudger.
      • For easier cap removal, hold the spudger vertically to the board and push, towards the bottom of the device.
      • Remove the five 5 mm screws from the rear panel of the device, using a Phillips #1 screwdriver.
      Ask FixBot
    3. Vtech InnoTab 3S Camera Replacement: step 3, image 1 of 2 Vtech InnoTab 3S Camera Replacement: step 3, image 2 of 2
      • Remove the six 7 mm screws from the interior battery compartment using a Phillips #1 screwdriver.
      Ask FixBot
    4. Vtech InnoTab 3S Camera Replacement: step 4, image 1 of 1
      • Carefully remove the rear panel from the device.
      • Once the rear panel is removed, the motherboard and other components in the Vtech InnoTab 3S are visible and accessible.
      Ask FixBot
    1. Vtech InnoTab 3S Camera Replacement, Camera: step 5, image 1 of 2 Vtech InnoTab 3S Camera Replacement, Camera: step 5, image 2 of 2
      • Using the tip of your finger, carefully pull the clip upwards to release the camera connection from the motherboard.
      • The connection between the motherboard and the camera is located at the near the top of the device.
      • Remove the camera and the connecting wire from the the clip and attach the replacement cameras connection to the latch on the motherboard.
      • Carefully lower the latch until you hear a click to secure the new camera to the device.
      • Pulling or tugging on the connection between the camera and the circuit board may cause damage to the connection.
      Ask FixBot
2 other people completed this guide.
Author
with
Karina Garcia
878 Reputation
6 Guides authored
USF Tampa, Team 8-2, Eyestone Fall 2015 Member of USF Tampa, Team 8-2, Eyestone Fall 2015
USFT-EYESTONE-F15S8G2
4 Members
108 Guides authored
4 Guide Comments
Where do you get the replacement camera? I can't find them online.
rongennero - Reply Share
I just did this whole thing...hoping it was a reset to the camera or something, but no, you need a replacement camera. Might be helpful to add that to the PARTS NEEDED part at the top, instead of saying "no parts required." UUGHHHH!
jpimash - Reply Share
Where can i buy the camera?
Stephan Meyer - Reply Share
kind of useless to post a replacement guide without suggesting a source for that replacement!!
Glen Fletcher - Reply Share
Past 24 Hours: 3
Past 7 Days: 13
Past 30 Days: 90
All Time: 2,658
