Vornado Duo Fuse Replacement
Views: 18K
View statistics:
Past 24 Hours:
4
Past 7 Days:
24
Past 30 Days:
147
All Time:
17,967
Comments: 6
6 guide comments.
Go to guide comments
Completed: 6
6 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 2 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
In this replacement guide, step-by-step instructions show how to approach replacing the fuse in the power cord plug of the Vornado Duo.
    1. Vornado Duo Fuse Replacement, Fuse: step 1, image 1 of 1
      • Grasp plug and remove from the receptacle or other outlet device.
      • Do not unplug by pulling on cord.
      Ask FixBot
    2. Vornado Duo Fuse Replacement: step 2, image 1 of 1
      • Open fuse cover by sliding access cover on top of attachment plug.
      Ask FixBot
    3. Vornado Duo Fuse Replacement: step 3, image 1 of 1
      Tool used on this step:
      Flathead 3/32" or 2.5 mm Screwdriver
      $5.49
      Buy
      • Remove fuse carefully by gently prying out the ends of the fuse from the receptacle again using the driver with the 2mm flathead.
      • Risk of fire. Replace fuse only with 2.5 Amp, 125 Volt fuse.
      Ask FixBot
    4. Vornado Duo Fuse Replacement: step 4, image 1 of 1
      • Install replacement fuse by first placing the end of the fuse into the fuse receptacle which is opposite of the blades of the plug, then carefully push in the other end. (Only push against the metal end of the fuse, not the glass center portion)
      Ask FixBot
    5. Vornado Duo Fuse Replacement: step 5, image 1 of 1
      • Close the fuse access cover by sliding the cover back into the plug until it is completely closed, latches and is flush with the face of the plug. (Risk of fire. Do not replace attachment plug. Contains a safety device that should not be removed.)
      Ask FixBot
Finish Line
6 other people completed this guide.
Tyler Pettenger
563 Reputation
3 Guides authored
USF Tampa, Team S1-G1, Nance Fall 2017 Member of USF Tampa, Team S1-G1, Nance Fall 2017
USFT-NANCE-F17S1G1
3 Members
48 Guides authored
6 Guide Comments
It’s still not working for me - I’ve cleaned the whole fan, put it back together and changed the fuse. Any tips? Thank you.
Whitney Sturner - Reply Share
Did you ever get an answer? I'm having the same problem
bysgamer617 - Reply Share
Probably a damaged circuit board capacitor, search out a micro-electronic repair shop. Or, authorized dealer. Often you can find a repair that understands multiple board systems and can easily test and repair your fan. An example, Apple technologies.
GW Roberts (GW) - Reply Share
Please remember, if you purchase the fan from any source other than an authorized dealership, who has invested money and training, the manufacturer has NO responsibility to that unauthorized purchase.
Is there “a tell” that the problem is the motor or circuit board before searching for fuses? For the 1st micro second it moves an inch like it’s getting power.
Djlaine17 - Reply Share
Past 24 Hours: 4
Past 7 Days: 24
Past 30 Days: 147
All Time: 17,967
