Up to 20% off select tools
VooDooQuad 250 Propeller Replacement
Views: 1.3K
View statistics:
Past 24 Hours:
4
Past 7 Days:
17
Past 30 Days:
97
All Time:
1,347
Comments: 1
1 guide comment.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 minutes
Difficulty: Very easy
Introduction
Go to step 1 ↓
Chipping or breaking of a propeller for any level drone flier is inevitable. It is an incredibly common troubleshoot, but luckily a simple replacement. Make sure you have a clean working station, and all you'll need is a set of pliers to put on the new set.
    1. VooDooQuad  250 Propeller Replacement, Propeller: step 1, image 1 of 2 VooDooQuad  250 Propeller Replacement, Propeller: step 1, image 2 of 2
      • Unplug the power cable of the drone to eliminate unnecessary mishaps.
      Ask FixBot
    2. VooDooQuad  250 Propeller Replacement: step 2, image 1 of 1
      • With your set of pliers loosen and remove the four bolts holding the propellers to the motor.
      Ask FixBot
    3. VooDooQuad  250 Propeller Replacement: step 3, image 1 of 2 VooDooQuad  250 Propeller Replacement: step 3, image 2 of 2
      • Gently remove the propellers perpendicular to the device.
      • When placing the new set of propellers on the drone, make sure that the wings angled upward are facing towards the center, or the battery.
      Ask FixBot
Be careful removing the bolts multiple times because it may create slippage and then this will not allow the bolt nor the propeller to stay on. To reassemble your device, follow these instructions in reverse order
Author
with
Damir Pamic
141 Reputation
1 Guide authored
USF Tampa, Team 10-3, Remmell Spring 2017 Member of USF Tampa, Team 10-3, Remmell Spring 2017
USFT-REMMELL-S17S10G3
4 Members
12 Guides authored
1 Guide Comment
Where do I purchase new perpelers
Will Smith - Reply Share
Past 24 Hours: 4
Past 7 Days: 17
Past 30 Days: 97
All Time: 1,347
