Voluas VL001 Screen/Motherboard Assembly Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
10
Past 30 Days:
52
All Time:
475
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Moderate
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓
If your Voluas VL001 pet feeder's display is not working or dispenses food at irregular times, you may have an issue with your screen/motherboard assembly. The display and motherboard are connected and are situated above the feeding chute.
Before you begin, power off the Voluas VL001 and unplug it from the power source. If it’s running on batteries, remove them first.
Tools
    1. Voluas VL001 Screen/Motherboard Assembly Replacement, Storage Tank: step 1, image 1 of 3 Voluas VL001 Screen/Motherboard Assembly Replacement, Storage Tank: step 1, image 2 of 3 Voluas VL001 Screen/Motherboard Assembly Replacement, Storage Tank: step 1, image 3 of 3
      • Remove the lid to the storage tank by using the latch and lifting off.
      • Grab the food storage tank on both sides. Depress the tabs that say "Push" on them and lift the tank off.
      Ask FixBot
    1. Voluas VL001 Screen/Motherboard Assembly Replacement, Battery: step 2, image 1 of 3 Voluas VL001 Screen/Motherboard Assembly Replacement, Battery: step 2, image 2 of 3 Voluas VL001 Screen/Motherboard Assembly Replacement, Battery: step 2, image 3 of 3
      • Place your pet feeder upside down.
      • Squeeze the lock and remove the battery cover.
      • Remove the three 1.5V D alkaline batteries.
      Ask FixBot
    1. Voluas VL001 Screen/Motherboard Assembly Replacement, Housing: step 3, image 1 of 3 Voluas VL001 Screen/Motherboard Assembly Replacement, Housing: step 3, image 2 of 3 Voluas VL001 Screen/Motherboard Assembly Replacement, Housing: step 3, image 3 of 3
      • Insert a metal spudger under the adhesive part of each rubber foot.
      • Pry the foot off.
      Ask FixBot
    2. Voluas VL001 Screen/Motherboard Assembly Replacement: step 4, image 1 of 2 Voluas VL001 Screen/Motherboard Assembly Replacement: step 4, image 2 of 2
      • Remove four screws from the corners of the device using a Phillips #2 screwdriver.
      • These holes were previously covered by the rubber feet.
      • Using the magnetic tip of the screwdriver, carefully lift the screw out of the hole.
      Ask FixBot
    3. Voluas VL001 Screen/Motherboard Assembly Replacement: step 5, image 1 of 1
      • Turn the device over so it is oriented right-side up.
      • Lift the top part of the feeder off, exposing the mechanisms that run the feeder.
      Ask FixBot
    1. Voluas VL001 Screen/Motherboard Assembly Replacement, Screen/Motherboard Assembly: step 6, image 1 of 2 Voluas VL001 Screen/Motherboard Assembly Replacement, Screen/Motherboard Assembly: step 6, image 2 of 2
      • With the top part of the feeder sitting upside down, you can remove the chute.
      • Using a Phillips #2 screwdriver, remove the two 11.1 mm screws on either side of the chute.
      Ask FixBot
    2. Voluas VL001 Screen/Motherboard Assembly Replacement: step 7, image 1 of 2 Voluas VL001 Screen/Motherboard Assembly Replacement: step 7, image 2 of 2
      • Grab the feeder chute on both sides and lift it off to remove it from the feeder.
      Ask FixBot
    3. Voluas VL001 Screen/Motherboard Assembly Replacement: step 8, image 1 of 3 Voluas VL001 Screen/Motherboard Assembly Replacement: step 8, image 2 of 3 Voluas VL001 Screen/Motherboard Assembly Replacement: step 8, image 3 of 3
      • Using your finger, depress the tab that holds the assembly onto the device.
      • While pushing the tab down, push the screen out of the device.
      Ask FixBot
    4. Voluas VL001 Screen/Motherboard Assembly Replacement: step 9, image 1 of 3 Voluas VL001 Screen/Motherboard Assembly Replacement: step 9, image 2 of 3 Voluas VL001 Screen/Motherboard Assembly Replacement: step 9, image 3 of 3
      • Using an opening tool, pry the dried silicone from around the connector.
      • Because you are working around the motherboard, try to limit how much you use its surface for leverage. It is a fragile part and can damage easily.
      • If needed, peel any remaining glue off with your fingers.
      Ask FixBot
    5. Voluas VL001 Screen/Motherboard Assembly Replacement: step 10, image 1 of 3 Voluas VL001 Screen/Motherboard Assembly Replacement: step 10, image 2 of 3 Voluas VL001 Screen/Motherboard Assembly Replacement: step 10, image 3 of 3
      • Firmly grab the connector, just above the plastic end, and pull firmly to remove.
      Ask FixBot
Jade Thomson
699 Reputation
6 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 52
All Time: 475
