Voluas VL001 Motor Assembly Gears Replacement
  1. Voluas VL001 Motor Assembly Gears Replacement, Storage Tank: step 1, image 1 of 3 Voluas VL001 Motor Assembly Gears Replacement, Storage Tank: step 1, image 2 of 3 Voluas VL001 Motor Assembly Gears Replacement, Storage Tank: step 1, image 3 of 3
    • Remove the lid to the storage tank by using the latch and lifting off.
    • Grab the food storage tank on both sides. Depress the tabs that say "Push" on them and lift the tank off.
    Ask FixBot
  2. Voluas VL001 Motor Assembly Gears Replacement, Battery: step 2, image 1 of 3 Voluas VL001 Motor Assembly Gears Replacement, Battery: step 2, image 2 of 3 Voluas VL001 Motor Assembly Gears Replacement, Battery: step 2, image 3 of 3
    • Place your pet feeder upside down.
    • Squeeze the lock and remove the battery cover.
    • Remove the three 1.5V D alkaline batteries.
    Ask FixBot
  3. Voluas VL001 Motor Assembly Gears Replacement, Housing: step 3, image 1 of 3 Voluas VL001 Motor Assembly Gears Replacement, Housing: step 3, image 2 of 3 Voluas VL001 Motor Assembly Gears Replacement, Housing: step 3, image 3 of 3
    • Insert a metal spudger under the adhesive part of each rubber foot.
    • Pry the foot off.
    Ask FixBot
  4. Voluas VL001 Motor Assembly Gears Replacement: step 4, image 1 of 2 Voluas VL001 Motor Assembly Gears Replacement: step 4, image 2 of 2
    • Remove four screws from the corners of the device using a Phillips #2 screwdriver.
    • These holes were previously covered by the rubber feet.
    • Using the magnetic tip of the screwdriver, carefully lift the screw out of the hole.
    Ask FixBot
  5. Voluas VL001 Motor Assembly Gears Replacement: step 5, image 1 of 1
    • Turn the device over so it is oriented right-side up.
    • Lift the top part of the feeder off, exposing the mechanisms that run the feeder.
    Ask FixBot
  6. Voluas VL001 Motor Assembly Gears Replacement, Motor Assembly Gears: step 6, image 1 of 3 Voluas VL001 Motor Assembly Gears Replacement, Motor Assembly Gears: step 6, image 2 of 3 Voluas VL001 Motor Assembly Gears Replacement, Motor Assembly Gears: step 6, image 3 of 3
    • Using a Phillips #2 screwdriver, remove the six screws that hold the motor housing on to the device.
    Ask FixBot
  7. Voluas VL001 Motor Assembly Gears Replacement: step 7, image 1 of 1
    • Lift the electric motor from its housing and move it aside.
    Ask FixBot
  8. Voluas VL001 Motor Assembly Gears Replacement: step 8, image 1 of 2 Voluas VL001 Motor Assembly Gears Replacement: step 8, image 2 of 2
    • Use the tweezers to remove the first gear that is placed on top.
    Ask FixBot
  9. Voluas VL001 Motor Assembly Gears Replacement: step 9, image 1 of 2 Voluas VL001 Motor Assembly Gears Replacement: step 9, image 2 of 2
    • Use the tweezers to gently remove the second gear.
    Ask FixBot
  10. Voluas VL001 Motor Assembly Gears Replacement: step 10, image 1 of 2 Voluas VL001 Motor Assembly Gears Replacement: step 10, image 2 of 2
    • Use the tweezers to gently remove the third gear.
    Ask FixBot
Jade Thomson
699 Reputation
6 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 29
All Time: 246
