Volt FX-8 Li Switch Replacement
View statistics:
Past 24 Hours:
4
Past 7 Days:
13
Past 30 Days:
67
All Time:
271
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 1 hour
Difficulty: Moderate
Community-Contributed Guide
Introduction
Go to step 1 ↓
My Volt FX-8 Li pool vac failed after one season. Although it had a warranty, the warranty was voided when I opened the "Battery Motor Box." This guide describes how to replace the failed switch and add a power transistor to handle the high current surge when the motor is turned on.
    1. Volt FX-8 Li Switch Replacement, The Problem: step 1, image 1 of 3 Volt FX-8 Li Switch Replacement, The Problem: step 1, image 2 of 3 Volt FX-8 Li Switch Replacement, The Problem: step 1, image 3 of 3
      • The premature failure of the switch is most likely related to exceeding its maximum current rating. An oscilloscope and current probe shows the voltage across the switch (red trace) and the current through the switch (yellow trace) at turn-on.
      • The peak current is about 26 A, the current exceeds 10 A for about 20 ms (large red rectangle). This peak current is determined by the battery voltage (12 V) divided by the motor resistance (0.5 ohms), 12 V / 0.5 ohm = 24 A.
      • The running (no load) current is about 2 A (small red rectangle). This current is determined by the battery voltage (12 V) minus the back EMF of the motor divided by the motor resistance.
      • The switch is rated 6 A DC (see photo).
      • Cutting the switch in half reveals a small burned spot on one of the switch contacts (see photo).
      • I also discovered that the charger adapter sometimes made a poor connection to the unit, cleaning the flat contacts solved the problem.
      Ask FixBot
    2. Volt FX-8 Li Switch Replacement, The Plan: step 2, image 1 of 2 Volt FX-8 Li Switch Replacement, The Plan: step 2, image 2 of 2
      • This guide describes replacement of the damaged switch and adding a power MOSFET (Metal-Oxide Semiconductor Field-Effect Transistor) to easily switch this high current.
      • The original schematic shows that the switch handles the entire motor current.
      • The modified schematic adds a power MOSFET to switch the motor current, now the physical switch passes only a very small current.
      • The wires from the old switch now connect to the MOSFET.
      • The wires from the new switch now connect to the battery and the gate (input) of the MOSFET.
      Ask FixBot
    3. Volt FX-8 Li Switch Replacement, Remove outer shell: step 3, image 1 of 2 Volt FX-8 Li Switch Replacement, Remove outer shell: step 3, image 2 of 2
      • Remove 7 screws from primary side.
      • Remove 2 screws from secondary side.
      • Remove both sides of outer shell.
      Ask FixBot
    4. Volt FX-8 Li Switch Replacement, Open Motor Box: step 4, image 1 of 1
      • Remove 8 screws from motor box cover.
      • This will void the warranty!
      • Carefully remove cover of motor box. Note that the edge of the cover is smooth, and there is a soft red gasket in the groove of the mating surface.
      • Take care not to damage or contaminate the gasket or the edge of the cover. This water-tight enclosure is important!
      Ask FixBot
    5. Volt FX-8 Li Switch Replacement, Disconnect battery: step 5, image 1 of 2 Volt FX-8 Li Switch Replacement, Disconnect battery: step 5, image 2 of 2
      • Use long-nose pliers to grip the push-on terminal connecting the red wire to the battery and pull it off of the battery terminal.
      • Tie or tape the lug so it doesn't touch the battery terminal.
      Ask FixBot
    6. Volt FX-8 Li Switch Replacement, Remove switch: step 6, image 1 of 3 Volt FX-8 Li Switch Replacement, Remove switch: step 6, image 2 of 3 Volt FX-8 Li Switch Replacement, Remove switch: step 6, image 3 of 3
      • Unscrew the knurled nut from the switch bushing (red circle).
      • Use a small screwdriver to carefully pry the latch away from the switch body (blue circle).
      • Carefully pull the switch from the switch mount.
      • Cut both switch wires leaving about 1/2" protruding from the switch body. (not shown).
      Ask FixBot
    7. Volt FX-8 Li Switch Replacement, Modify new switch: step 7, image 1 of 3 Volt FX-8 Li Switch Replacement, Modify new switch: step 7, image 2 of 3 Volt FX-8 Li Switch Replacement, Modify new switch: step 7, image 3 of 3
      • Your old and new switches may vary from what is shown in this guide. This new switch has a metal nut embedded in a plastic cap with a soft cover.
      • Break the plastic pieces off of the metal switch nut.
      • Carefully compare the old and new switch. In this example the new switch is slightly thinner and slightly longer.
      • File a groove in the rear of the new switch so that the retaining clip will hold the new switch in place similar to the way it held the old switch (red circle).
      Ask FixBot
    8. Volt FX-8 Li Switch Replacement, Install new switch: step 8, image 1 of 2 Volt FX-8 Li Switch Replacement, Install new switch: step 8, image 2 of 2
      • Install the new switch so the retaining clip holds it in position (red circle).
      • Add the knurled nut (red rectangle) and tighten it so switch is secure.
      • Force hot glue into the space behind the switch (blue rectangle).
      • Add some hot glue to secure the knurled nut (not shown).
      Ask FixBot
    9. Volt FX-8 Li Switch Replacement, Install resistor on MOSFET: step 9, image 1 of 2 Volt FX-8 Li Switch Replacement, Install resistor on MOSFET: step 9, image 2 of 2
      • Place the resistor against the body of the MOSFET. (This resistor is OLD, yours may look slightly different.)
      • Wrap the resistor leads around the two outside leads of the MOSFET as shown.
      • Cut the resistor leads as shown to leave room for the wire connections.
      • Cut the two outside MOSFET leads as shown.
      Ask FixBot
    10. Volt FX-8 Li Switch Replacement, Connect old switch leads: step 10, image 1 of 2 Volt FX-8 Li Switch Replacement, Connect old switch leads: step 10, image 2 of 2
      • Locate the two old switch leads (Blue in the adjacent wiring diagram).
      • Cut two 1/2" long pieces of 1/8" heat shrink tubing and slide one over each lead.
      • Strip 3/16" of insulation from the end of each lead.
      • Wrap the resistor lead at the source ("S") lead of the MOSFET around the exposed portion of the old switch lead coming from the battery.
      • Solder the connection.
      • Using long-nose pliers, form a hook in the center lead (drain or "D") of the MOSFET. Form the hook around the exposed portion of the old switch lead coming from the motor.
      Ask FixBot
    11. Volt FX-8 Li Switch Replacement, Connect new switch leads: step 11, image 1 of 2 Volt FX-8 Li Switch Replacement, Connect new switch leads: step 11, image 2 of 2
      • Select one of the new switch leads (red in the adjacent wiring diagram).
      • Cut one1/2" long pieces of 1/8" heat shrink tubing and slide it over the lead.
      • Remove the pre-stripped insulation from the end of the lead. Cut the exposed wire to 3/16".
      • Wrap the resistor lead at the gate ("G") lead of the MOSFET around the exposed portion of the new switch lead.
      • Select the other new switch lead (red in the adjacent wiring diagram).
      • Solder the lead to the positive terminal of the motor (alongside the red wire from the battery).
      Ask FixBot
    12. Volt FX-8 Li Switch Replacement, Cover MOSFET connections: step 12, image 1 of 2 Volt FX-8 Li Switch Replacement, Cover MOSFET connections: step 12, image 2 of 2
      • Slide the previously placed pieces of heat shrink tubing over each of the MOSFET terminals.
      • The tubing may snag on protruding stubs of wire. This is usually resolved with a little patience, or in some cases by trimming a protruding stub or re-soldering the wire.
      • Use the butane lighter to shrink the heat shrink tubing. Apply heat to both sides of the assembly to obtain uniform shrinkage.
      • Limit the heating to avoid burning the heat shrink tubing.
      • The entire MOSFET will be covered with the large shrink tubing after testing.
      Ask FixBot
    13. Volt FX-8 Li Switch Replacement, Reconnect battery: step 13, image 1 of 1
      • Turn the switch OFF and position the MOSFET so the metal tab is not touching any metal or wiring.
      • When off, the switch button protrudes from the bushing less than when it is on.
      • Momentarily touch the red wire terminal to the battery terminal.
      • If the motor runs immediately, check for shorts or other problems. A multimeter may be helpful to diagnose problems.
      • If the motor did not run immediately, reconnect the red wire to the battery terminal.
      Ask FixBot
      • Turn the motor on and off (push the switch) quickly several times. The on/off action should be immediate.
      • Do not leave the motor running.
      Ask FixBot
    14. Volt FX-8 Li Switch Replacement, Add heat shrink tubing over MOSFET: step 15, image 1 of 1
      • Cut a 1.5" length of 1/2" diameter heat shrink tubing.
      • Slide the heat shrink tubing over the MOSFET, connections, and small shrink tubing.
      • Use the butane lighter to shrink the tubing.
      • Position the lighter and MOSFET to shrink all sides of the tubing.
      Ask FixBot
    15. Volt FX-8 Li Switch Replacement, Secure MOSFET under motor: step 16, image 1 of 1
      • Slide the covered MOSFET under the center of the motor (red circle).
      • There are some exposed gears near the motor, keep everything away from the gears.
      • Apply the cable tie (blue lines) around the motor and the MOSFET.
      • Tighten cable tie securely.
      • Cut off protruding end of cable tie.
      Ask FixBot
    16. Volt FX-8 Li Switch Replacement, Reinstall motor box cover: step 17, image 1 of 1
      • Inspect red gasket and edge of motor box cover. Clean off any debris.
      • Position motor box cover for installation.
      • When motor box cover has only a small gap around the perimeter inspect carefully to verify that no wires are in danger of being pinched.
      • The screws for the motor box have washer heads, the screws for the shell have standard pan heads.
      • Install two screws on opposite sides to temporarily fasten motor box cover.
      • Turn motor on and off several times to verify operation.
      • Install and uniformly tighten all screws for motor box cover.
      • When tightened there should be no visible crack around the perimeter of the cover.
      Ask FixBot
    17. Volt FX-8 Li Switch Replacement, Reassemble shells: step 18, image 1 of 2 Volt FX-8 Li Switch Replacement, Reassemble shells: step 18, image 2 of 2
      • Reassemble both shells.
      • Install and tighten all screws (7 on primary side, 2 on secondary side).
      Ask FixBot
Done!
Frank Demarest
1,079 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 13
Past 30 Days: 67
All Time: 271
