Vizio VTAB1008 Battery Replacement
    1. Vizio VTAB1008 Battery Replacement, Vizio VTAB1008 Back Cover Removal: step 1, image 1 of 2 Vizio VTAB1008 Battery Replacement, Vizio VTAB1008 Back Cover Removal: step 1, image 2 of 2
      • Carefully slide the heavy duty opening tool between the gap on the side of the device with no buttons.
      • Do not insert the opening tool too far into the tablet as this can damage connectors close to edges of the cover.
      • The angled tip of the opening tool can be wedged into the device by pressing on the back of the opening tool with the thumb. Move the opening tool in a sliding motion to ensure all tabs separate.
      • Corner tabs may require a more forceful prying tool. If needed, carefully insert the metal prying tool into corners to separate the tabs.
      Ask FixBot
    2. Vizio VTAB1008 Battery Replacement: step 2, image 1 of 1
      • Look into the tablet for loose connectors.
      • There are three loose connectors: one for the screen, one for the digitizer, and one for the motherboard. They are held in place by the pressure of the backing and screen assemblies.
      • Flip the backing from the button-less side over, being careful not to separate the ribbon connector from the display screen.
      Ask FixBot
    1. Vizio VTAB1008 Battery Replacement, Battery: step 3, image 1 of 3 Vizio VTAB1008 Battery Replacement, Battery: step 3, image 2 of 3 Vizio VTAB1008 Battery Replacement, Battery: step 3, image 3 of 3
      • Remove the ribbon strip that crosses the battery from both ends.
      • A blue opening tool may be used to assist.
      Ask FixBot
    2. Vizio VTAB1008 Battery Replacement: step 4, image 1 of 2 Vizio VTAB1008 Battery Replacement: step 4, image 2 of 2
      Tool used on this step:
      Buy
      • Remove the connector at the top of the motherboard by pulling out and away from the motherboard.
      • This is the connector with the wires leading to the battery.
      • Tweezers may help.
      Ask FixBot
    3. Vizio VTAB1008 Battery Replacement: step 5, image 1 of 3 Vizio VTAB1008 Battery Replacement: step 5, image 2 of 3 Vizio VTAB1008 Battery Replacement: step 5, image 3 of 3
      • Pull the battery away from the back panel.
      • A metal spudger may be needed to pry the battery from the backing.
      • The battery is glued to the back panel and caution should be used as to not break or rupture the battery pack.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 25
Past 30 Days: 105
All Time: 1,944
