Vizio Tablet Micro USB Charging Port Replacement
    1. Vizio Tablet Micro USB Charging Port Replacement, Micro USB Charging Port: step 1, image 1 of 3 Vizio Tablet Micro USB Charging Port Replacement, Micro USB Charging Port: step 1, image 2 of 3 Vizio Tablet Micro USB Charging Port Replacement, Micro USB Charging Port: step 1, image 3 of 3
      • Begin by using the plastic opening tool to take off the back of the tablet.
      • Starting from the sides can make the process easier.
      Ask FixBot
    2. Vizio Tablet Micro USB Charging Port Replacement: step 2, image 1 of 1
      • Use the plastic opening tool to disconnect the LCD screen.
      Ask FixBot
    3. Vizio Tablet Micro USB Charging Port Replacement: step 3, image 1 of 1
      • Use the plastic opening tool to disconnect the camera.
      Ask FixBot
    4. Vizio Tablet Micro USB Charging Port Replacement: step 4, image 1 of 1
      • Use the plastic opening tool to disconnect both of the volume buttons.
      Ask FixBot
    5. Vizio Tablet Micro USB Charging Port Replacement: step 5, image 1 of 2 Vizio Tablet Micro USB Charging Port Replacement: step 5, image 2 of 2
      • Then, remove all four of the 2.3 mm Phillips screws.
      Ask FixBot
    6. Vizio Tablet Micro USB Charging Port Replacement: step 6, image 1 of 1
      • Remove the circuit board from the platform.
      Ask FixBot
    7. Vizio Tablet Micro USB Charging Port Replacement: step 7, image 1 of 1
      • Remove the USB port from the circuit board.
      Ask FixBot
    8. Vizio Tablet Micro USB Charging Port Replacement: step 8, image 1 of 1
      • Insert the new USB port onto the circuit board.
      Ask FixBot
    9. Vizio Tablet Micro USB Charging Port Replacement: step 9, image 1 of 1
      • Lastly, fuse the USB port back onto the circuit board.
      Ask FixBot
Jose
125 Reputation
1 Guide authored
1 Guide Comment
Thank you it was very helpful simple and straight to the point
sirhc89chris - Reply Share
Past 24 Hours: 5
Past 7 Days: 20
Past 30 Days: 86
All Time: 1,297
